battery draining
Old Jan 31, 2015 | 12:14 PM
nujagowner's Avatar
Default battery draining
Hello from New Member. I currently own a 97 XK8, and had a problem with taillight burning out. When I pulled the taillight assemblies out to replace bulbs, I found the bulbs getting VERY hot. After reading your post, I added a ground wire to each assembly, and connected to the body where the assembly screws to the body. I haven't had anymore bulbs burn out, but I am having a problem with my battery dying. I don't know if this is a totally separate issue, or related to installing the ground wires. Has anyone had a similar issue?
When running, the amp gauge shows normal, so it seems the battery is charging fine when running. When turning the key to start, the battery shows a lower than normal charge. Could adding the ground wires have any detrimental effect on the battery?
Thanks in advance for any advice!
Old Jan 31, 2015 | 12:31 PM
nujagowner, I've moved your post to its own thread vice on the tail end of an old resolved thread.
How old is the battery in the car? Most batteries have 3 to 5 years worth of life, so I would take the car to an Advance Auto or similar place and have the battery & charging system tested.
As this is your first post, please stop by the New Member area and post an intro. in return, you will receive a warm welcome and some useful tips on navigating the forum
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
regards
Steve
Old Jan 31, 2015 | 01:28 PM
Cee Jay's Avatar
Search the forum for CTEK BATTERY MAINTAINER. Us XK8/R - XK/R owners know the problems of low-use vehicles and heavy drain electronics.
By hooking up a battery maintainer, the battery will always have a 100% full charge, no matter how long it sat before use.
If not THE problem you're currently having, it will help you diagnose your NEW problem. It's also a really good thing to have, that maintainer. You'll be happy you got one.
aholbro1
Dec 29, 2024 06:46 PM
lighterthanair
Sep 24, 2015 08:36 PM
puddled
Sep 22, 2015 03:57 AM
Charlene n John
Sep 14, 2015 10:08 AM
obwoodie
Sep 3, 2015 07:45 PM
