Battery replacement 02 xkr
Old Sep 26, 2016 | 03:34 PM
lossking_'s Avatar
Default Battery replacement 02 xkr
I'm going to be changing my battery pretty soon. I wanted to know if there was any certain specs I need to know about and what kind of battery or brand I should get? I want to be sure before pulling the plug off the old one.
Old Sep 26, 2016 | 04:40 PM
Rick L's Avatar
The type you order if a direct replacement is vented. Make sure you have the vent hose either from the old one or they should supply a vent hose with the new battery. You should also get a battery tender if you don't drive it daily. A low voltage battery is the cause of most of the electrical problem posted here.
Old Sep 26, 2016 | 04:44 PM
test point's Avatar
Nice car!
The principal issue is that a vented battery is required.
Some batteries that are vented capable do not have the attachment pieces supplied or installed. The vent is usually at one or both ends of the case. If installed by an auto parts store or technician ensure that the vent system is installed.
Make sure that the corrosive and explosive gas goes outside.
Other than that meet the CCA recommendations from Jaguar and get a case that matches the hold down hardware.
Old Sep 26, 2016 | 04:45 PM
hirev's Avatar
FYI, not the exact same car but my xk8 has a new Bosch battery from pep boys, about 160.00, best of luck
Old Sep 26, 2016 | 05:21 PM
lossking_'s Avatar
Originally Posted by test point
Nice car!
Is there a certain size that must be bought?
Old Sep 26, 2016 | 05:31 PM
test point's Avatar
The AGM battery is a H8. In lead/acid it is a group 49,
I have had excellent service out of AGM sealed batteries,
Old Sep 26, 2016 | 07:05 PM
Dr. D's Avatar
+1.... I bought mine thru Advance auto online and picked it up locally using a $50 off coupon code
Old Jul 21, 2018 | 08:54 AM
RyanD's Avatar
Where does the vent hose connect on the other end? In other words, where does it vent to?
Old Jul 21, 2018 | 11:06 PM
zray's Avatar
I put in a AGM battery from NAPA in my 02 XKR coupe ( from their best line, NAPA LEGEND PREMIUM ) when I bought the car. Fit perfectly. Consistently has voltage of 12.7 V
it's this one:
https://www.napaonline.com/en/p/NBP9849
Z
Old Jul 22, 2018 | 05:04 AM
michaelh's Avatar
Through a grommet in the boot floor. See this thread by Steve-in-ct:
https://www.jaguarforums.com/forum/x...8/#post1682648
ecamiel
Sep 1, 2019 03:37 PM
muskox3437
19
Oct 13, 2016 09:52 AM
jaghag00
Sep 26, 2016 07:40 PM
XJ8Lou
Sep 26, 2016 03:40 PM
Alex O'Brien
XK120 XK140 XK150
Sep 25, 2016 09:49 PM
