BBS Detroit alloy original ring material?
Old Jul 3, 2020 | 02:23 AM
tsuppari's Avatar
Default BBS Detroit alloy original ring material?
Hi, got my hands on Detroit alloys w/bargain price & common kerb damage on rings.
Wondering what material are original rings?
(afaik aftermarket ones from UK are steel)
Old Jul 3, 2020 | 04:12 AM
baxtor's Avatar
As far as l know they have always been polished stainless steel.
I have couple of brand new never fitted rears I picked up from old dealer stock and they actually have no trim fitted.
Old Jul 3, 2020 | 04:30 AM
The Sepang on my 2005 XK8 used the same trim ring as Detroit. Never saw anything other than stainless steel OE or aftermarket trim rings advertised.
Old Jul 3, 2020 | 07:11 AM
frankc's Avatar
I agree with both of the above. I had my wheels rings replaced a while ago. £100+ Each
Old Jul 6, 2020 | 11:53 AM
tsuppari's Avatar
After tire remove & removal of centers (bolts did come out cleanly w/o hassle) I examined rings more closely:
- they are painted
- pretty soft as can be abraded w/hand file without force
- there was hand-written A/B/C/D letters inside rims and centers
So I suspect that rings on these rims are aluminum and already replaced once or what you think (see picture, red square shows some hand file test)
Non OE BBs ring?
Old Jul 6, 2020 | 08:31 PM
baxtor's Avatar
- they are painted
Non OE BBs ring?
That appears to be the rim itself. Trim ring is fitted over that rim on the BBS wheels. Is that simply one side of the barrel or are your wheels actually "split" rims? Picture unclear.
Possibly damaged in the past and since removed or never fitted.
Old Jul 7, 2020 | 03:17 AM
Here's a Trim Ring:
No fixing holes.
Old Jul 7, 2020 | 05:45 AM
tsuppari's Avatar
Here is bit more detailed picture before I dismantled rims. I'll get better pictures after I wash barrels. Steel ring should be quite thin to fit.
But yea, that could be a case that rings had been removed already.
Closeup
Similar rim 'ring' (on sell somewhere)
Old Jul 7, 2020 | 07:03 AM
baxtor's Avatar
Closeup
trim rings will totally fix those wheels.
they are not cheap but easy enough to fit (instructions available online)
l have a couple of spare new old stock rears, never fitted and trim rings are not fitted so maybe in some instances they were not fitted.
Old Jul 7, 2020 | 08:14 AM
Here's a comparison of split rim alloys with and without Trim Ring fitted. These are Sepang but the same Trim Ring fits yours.
WITH Trim Ring:
WITHOUT Trim Ring:
The thin stainless steel Trim Ring fits over the outer section of the aluminium.
Old Jul 7, 2020 | 04:18 PM
YYC guy's Avatar
Default 20"BBS rings
Does anyone have a source for the rings? I would like to replace all the 20" rings on my Detroit's. All have the dreaded curb rash some were my fault some not.
Old Jul 8, 2020 | 10:31 PM
bcprice36's Avatar
Shoot! I just wrote a Book about BBS SS Wheel Rings....It was so interesting that I thought I would send you Guys a Picture of one but when I pushed the wrong button everything went away.....So, I will keep this one short: You can buy BBS Gear and I mean everything from: Sales@sbwheels.co.uk
I better Sign-off before I lose this..
Billy Clyde
Old Jul 9, 2020 | 11:57 AM
YYC guy's Avatar
Thanks Billy Clyde,
I will email the company today.
Old Jul 9, 2020 | 07:48 PM
bcprice36's Avatar
YYC guy,
Those SS Rings are easy to work with...if you have Curb-Rash...I got sort'a forced into a Curb by some Guy about a year ago...so the Right Rear got about 10" or 12" of "Curb Rash",,,,, ,Looked real BAD! Went to Harbor Tools and bought a Rasp and (2) Files... Started with the Rasp and cut the heavy stuff off...Then the little File, as I didn't need the Medium one...Worked for a little while with it and then got my Body Sand Paper (800) then (1600)...Now you can't see where the Rash was.....It's nice and shiney now! Saved a Hundred Bucks!
Billy Clyde
Andy_XKR
Aug 11, 2019 02:15 PM
trevor24
UK & Eire
Jul 7, 2016 02:16 AM
osyris
Jan 5, 2013 04:19 PM
nurquhar
Aug 27, 2012 12:36 PM
Walter1982
Apr 8, 2009 04:52 PM
