can headlight washers be aimed
Is there a process for aiming the headlight washers? My hood and anything nearby gets soaked when I use them.
Doug
Do these washers actually do anything. Never tried them. Seems useless without a wiper of sorts. I think it would be easier to follow a tractor trailer truck for a few miles on a rainy day.
Mine do a better job of spraying the winsheild than the wiper washers do!
Last time I had my state inspection done the guy had me turn headlights on to check them first, left them on then hit the wipers. Sprayed the tech in the face!
I've always thought they are completely useless, only included because other prestige vehicle manufacturers fit them and the Jaguar presumption is that buyers expect them in the list of toys.
However, I'm obsessive with my cars and if something is fitted, it must work properly so fuse pulling or other disabling techniques is not for me.
Living on the "wet coast" of Canada I find them real helpful to clear the road film and keep them bright.
IMHO... the best road film remover is made in Comox BC .... North Vancouver Island ...called CV9 ...sold in of all places the local Winsor Plywood lumber store.
Ive used it for over 30 years and I just cuts road film ....period
Cheers,
Andy
Cheers,
Andy
Doug
I'm kind of the same way. In California I never need or intend to use these but was impressed that such a gizmo came on the car. Still I do want them to be operable. Amazing that Jaguar would have included something like this but did NOT include a low tire pressure sensor.
Doug
Doug
there are some very nice add on systems out there. the one that i installed works very well and is a lot cheaper and easier to replace than one of the factory internal sensors in other cars. the aftermarket units provide almost real-time data which is nice for adjusting performance and finding slow leaks before they become an inconvenience. the units are very precise and one can have a nice OCD time with the pressures
the unit that i purchased is not longer available, however similar solutions exist. the wheel air-stem sensors use replaceable batteries and the head unit is solar.
TPMS was rather new, probably non-existent, when our cars were designed. it is surprising that this was not added when the cars received the major tech update of 2003.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I had a 95 Corvette and the LTPWS was not standard except (I think) if you bought the run-flat tires. In any case the technology was clearly there in the early 1990s. Our cars were at least $75K and the real PITA was if you got the $6K premium wheel option with the BBS wheels. Since checking air in these is a real chore due to the special screw on stem, you would have thought that the extra $6K would have included a pressure monitoring system.
Doug
Doug
Doug
Doug
And with the hidden headlights, don't know how they would have put a headlamp washing system on it.
Doug
