can't clear ECM
Old Jan 23, 2021 | 12:57 AM
jaguar jon02's Avatar
Default can't clear ECM
can't clear ECM, the engine in my 99 XKR shot craps, replaced engine. will start and die ,have codes for upstream oxy sensors bank 1 &2, crank sensor( put in new one) my scanner want clear codes on this car. will on all my others., left battery out all night ,hoping to clear codes like on most cars and codes still there, anybody have any ideas
Old Jan 23, 2021 | 05:46 AM
If it STARTS then DIES, you are likely to have a fuel feed issue. A subset of DTC's intentionally have the effect of putting the vehicle into "reduced performance" or "limp home" mode but the engine will usually continue to run in these circumstances.
You have fitted a matching engine sourced from a 99 XKR and not a later iteration of the V8?
Odd that a scanner won't clear codes as even the most basic normally do this. Perhaps Jaguar SDD is going to be required to troubleshoot this.
Old Jan 23, 2021 | 08:25 AM
JagV8's Avatar
In case there are particular kinds of faults, when you clear the DTCs they will immediately occur again. The result can be that you think the codes didn't clear.
Old Jan 23, 2021 | 08:35 AM
motorcarman's Avatar
The XKR was introduced in the US for MY 2000. Possibly your car was manufactured in 1999 but the US considers it a 2000MY. (AJ27)
The XJR engines 1998 and 1999 are AJ26 and are not 'Plug & Play'. (many differences)
If you needed a replacement engine, your car requires an AJ27 from a 2000 to 2002 XKR or a 2000 to 2003 XJR 4.0.
The AJ26 will require many 'modifications' to work in your car.
Old Jan 23, 2021 | 12:57 PM
fmertz's Avatar
Remember, our cars will report a P1000 immediately after a reset to indicate the OBDII monitors have not cleared. Even a "healty" OBDII status will report P1111.
Old Jan 24, 2021 | 09:23 AM
they said it came from a 99 xjr but now will have double ck. wonder why codes want clear with battery undone like most cars , haven't started it and codes still there, thanks you guys for the help
Old Jan 24, 2021 | 09:34 AM
thanks motorcarman they said it came out of 99 xjr, think i'm screwed., thought they were the same have old motor can i change parts
Old Jan 24, 2021 | 09:40 AM
thanks motorcarman said out of 99 xjr think i'm screwed.. also have a friends 99 xk8 needing a motor will i run into same problem?
Old Jan 24, 2021 | 12:33 PM
JayJagJay's Avatar
Sometimes a hard reset will take a little more than just discon battery. I usually clip the post and neg bat leads together OR clip the neg to the positive terminal over night. When I started my XK8 after engine swap and messing around with O2 sensors car would die too, at first, until I got the advice from these dudes and did a REAL reset. Then the car worked to find it's new baseline as is supposed to. The jarring new info from the new motor and bits was too much for the ECU, I figure...
​​​​​​The O2 sensors shouldn't stop the car running, while the crank sensor will. I would worry about the good-ness of the new crank sensor of course, but not the code clearing so much. I'm sure you want to be able to read NEW codes tho, as you progress...
Dude, if ya ended up getting sold a not as described engine, I'm sorry to hear that. That's a real bummer. Damn suppliers!
Old Jan 24, 2021 | 01:54 PM
The CKPS segments on the torque converter drive plate and CMPS reluctor count on the intake cam(s) are DIFFERENT.
This AJ26/AJ27 swap and difference has been discussed REPEATEDLY on this forum.
You will get faults logged if you try to run a different engine in a car with an ECM properly configured to THAT CAR. (usually CKPS/CMPS relationship)
The AJ26 engine will not work in the AJ27 car (and vise versa) without many swaps/modifications.
Old Jan 25, 2021 | 08:27 AM
haven't been on in awhile no problems till now, title says 99 but it was a total drop top. they took 2 cars and made 1 so will have to check vin
Oxidizer2k
Dec 31, 2020 02:56 AM
shawnethan
Mar 11, 2014 01:31 PM
Crosbo
Apr 8, 2011 08:43 AM
Crosbo
Dec 17, 2009 02:42 AM
99kyxjr
Dec 10, 2009 02:10 PM
