The Clamp from hell
Old Mar 11, 2020 | 04:14 PM
David Dougherty's Avatar
Default The Clamp from hell
Just when I thought is was gonna get easy. I ran into this metal "pinch together" clamp on the partial load breather that I need to replace.
Does any body know of a trick to open this. I realize this is a one time destroy it clamp but it is made out ot very tough steel. PITA
Here is the little darling.
Old Mar 11, 2020 | 05:03 PM
graham11's Avatar
This is called a hose clamp,hose clamp pliers are easy to come across at most auto shops or on line
Old Mar 11, 2020 | 07:23 PM
RJ237's Avatar
Use regular pliers to squeeze, then a thin screwdriver slipped in to release. It is reusable, just mess with it and you will figure it out.
Old Mar 11, 2020 | 07:42 PM
avern1's Avatar
These clamps are QUICK release type. They are also reusable. Follow the link below and go to Post #6 nice color details on how they open and close.
https://www.jaguarforums.com/forum/x...-clamps-89769/
Old Mar 12, 2020 | 04:13 AM
bladerunner919's Avatar
Literally the easiest clamps to undo and reuse!
Old Mar 12, 2020 | 08:20 AM
Barry_Tucker's Avatar
I can't stand those things I cut them off as required and replace with jubilee clips as I am going
Old Mar 12, 2020 | 09:26 AM
They are used for two reasons:
1. speed of assembly
2. cannot be overtightened and crush plastic coolant outlet pipes
Old Mar 12, 2020 | 12:48 PM
Mad Hatter's Avatar
Stick a flathead screwdriver between the moving part and the stationary part of the clasp and twist the screwdriver, it will open.
Old Mar 12, 2020 | 01:59 PM
Understood. I am not worried about speed and I have not overtightened anything in 4 decades
Old Mar 12, 2020 | 02:36 PM
NBCat's Avatar
They are Oetiker clamps (https://www.oetiker.com/en/About-Us/...ogies/PexGrip/) and are designed for even sealing around a hose connection, especially with plastic pipes.
It's not a good idea to use jubilee clips or worm-type clamps when connecting a hose to a plastic pipe as they don't allow for dimensional changes due to heat and will eventually cause the plastic pipe connection to fail.
Old Mar 12, 2020 | 10:16 PM
Don B's Avatar
Another reason not to use a Jubilee clip/worm-gear clamp in place of an Oetiker or spring-type constant-tension clamp on any plastic pipe or fitting is that during thermal cycles the flat spot under the screw allows that section of pipe to expand and deform to a greater degree than the rest of the circumference, which promotes cracking/failure at that point of the pipe or fitting.
Probesport
Aug 11, 2021 02:41 PM
RobinGa
Oct 23, 2016 06:09 AM
larney
Jun 5, 2016 02:28 AM
larney
Jun 3, 2016 08:49 PM
RaceDiagnostics
Dec 20, 2015 08:24 AM
