Convertible Top Help!!
Old Mar 12, 2012 | 05:47 PM
Italianguy63's Avatar
Default Convertible Top Help!!
Stupid me. Was trying to figure out how to have the top down and all 4 windows up... for tint installation.
I did not let the top complete it's sequence to go up or down. Basically, I stoped it at 90% up. Now it won't go up or down, although I can hear relays click when I attempt. I did not experience a green shower.
What do I do? Where do I start?
MC
Old Mar 12, 2012 | 06:18 PM
WhiteXKR's Avatar
It is in the owner's manual. Basically release the petcock on the pump, grab the emergency hex wrench clipped in front of the pump, pull the round plastic plug out on the header, pull the top closed with the hand grip and turn the latch with the wrench while you are closing it.
Old Mar 12, 2012 | 06:21 PM
I found it thanks. Blown 40A fuse #14. Got the top back up. So, original question. How can I put the top down with all 4 windows up so tint can be applied? MC
Old Mar 12, 2012 | 06:32 PM
WhiteXKR's Avatar
Do you have JTIS?
Old Mar 12, 2012 | 06:39 PM
Some of it... It kind of works but only downloaded CD#1
Old Mar 12, 2012 | 06:44 PM
Gus's Avatar
Gus
I think Steve can help you with closing the windows electrically; however, you can do this manually and this link to my page should help. JagRepair.com - Jaguar Repair Information Resource I was going to respond to your first problem but I see you found a blown fuse.
Old Mar 12, 2012 | 06:51 PM
OMG.. So no "easy" answer...
Old Mar 12, 2012 | 07:00 PM
Gus's Avatar
Gus
No this cars roof system is complicated but your request can be done but you will need to do a workaround.
Old Mar 12, 2012 | 07:32 PM
WhiteXKR's Avatar
Lower the top and raise the front windows.
Open the trunk and access the trunk fusebox. Note the four small relays as in the photo.
The function of the relays is as follows:
Upper left: Left quarter window raise
Lower left: Left quarter window lower
Upper right: Right quarter window raise
Lower right: Right quarter window lower
Note the orange jumper wire in the photo. This is currently set to lower the left quarter window. if instead you want to raise the left quarter window, move the jumper wire to the same relative pins on the upper left relay socket, etc. Just keep the jumper connected long enough to complete the window movement. Do not connect more than one jumper at a time.
Do not forget to lower the rear windows before you raise the top back up, or else the top seals could be damaged.
Last edited by WhiteXKR; Mar 12, 2012 at 07:38 PM. Reason: Added clarification not to connect more than one jumper at a time.
Old Mar 13, 2012 | 03:32 AM
That will work! Thanks Steve, I dropped the car off for tint yesterday at the detailer yesterday. I will have to run by and work the windows so he can do the work.... Mark
Old Mar 13, 2012 | 09:49 AM
SeismicGuy's Avatar
I hope this isn't a foreboding of pump failure. When this fuse blew in my car it meant that the pump motor had failed, which I eventually replaced.
Doug
Old Mar 13, 2012 | 09:55 AM
Hopefully just my stupidity. I quit in mid-process... and probably stressed it, couldn't get "out of the hole" and drew too many amps...
Old Mar 13, 2012 | 10:04 PM
H20boy's Avatar
hey italianguy, i'm curious who you're trying to convince so enthusiastically I too hope it was just coincidence, did you by chance cycle it more than once or twice in succession?
Old Mar 14, 2012 | 03:21 AM
I probably cycled it 15 times trying to figure out what the heck was up....
Old Mar 14, 2012 | 04:09 AM
Hey Steve-- one more wrinkle for your instructions. The oposing relay has to be in place for this to work. i.e. the UP relay has to be in for the DOWN jumper to work, and vice-versa. I pulled all 4 relays at first (BTW they have little keepers on the left and are hard to pull), and the jumper didn't work. I had to put one of the two relays back in to make the windows operate. Thanks for the help again, should have Abbey back tonight from the detailer/tint. They had the rear and side door windows done yesterday.. MC
Old Mar 14, 2012 | 08:14 PM
WhiteXKR's Avatar
Good point!...I am glad you figured it out.
FrickenJag
Jun 16, 2025 02:15 PM
1100me
Jul 24, 2023 06:10 PM
Rivguy
Dec 4, 2020 07:55 AM
1100me
Sep 7, 2015 06:26 AM
jfitzoz
Sep 7, 2015 04:28 AM
