Coolant leak at 3 way connector-Norma connection of octopusus
Old Jul 9, 2025 | 01:31 PM
earny's Avatar
Default Coolant leak at 3 way connector-Norma connection of octopusus
Hello, my new arrival (XK8 4.2 Convertible) has a coolant leak at the 3 way connector and the norma clip of the octopus hose.
I have a new 3 way connector from my X308 XJR and its the same part number for the XK. Is there an additional O-Ring, when I manage to loosen the norma clip? I would like to try to stop the leak with the new 3 way connector and possibly a rubber O-Ring.
Thx in advance, Bernd from Cologne
And this is my "new" XK8 after a 650 Kilometer trip last Saturday (my XK was imported in 2018 from California, now 86000mls on the clock):
Old Jul 9, 2025 | 01:38 PM
xalty's Avatar
o-ring is on the octopus hose. lube it up and reuse
Old Jul 9, 2025 | 02:46 PM
earny's Avatar
Good news, thx! Hope to postpone the octopus-job for some time.
Old Jul 9, 2025 | 03:25 PM
RJ237's Avatar
If the fitting disintegrates you can probably use a brass tee.
Old Jul 28, 2025 | 04:25 AM
earny's Avatar
Short update: the norma-connector fitting broke immediately after "touching" when trying to loosen from the T-piece. As described here I cut the norma connector from the octopus hose and used a brass T piece, new clamps and a short piece of a new coolant hose and connected all hoses. So far no leaks, all dry. Thx a lot!
Old Nov 10, 2025 | 09:55 AM
Krotof1a's Avatar
Hello, I have exactly the same issue. I bought a new 3way plastic tube but I am unable to remove the norma connector side from the old one. I am almost ready to cut it away ... @earny could you d'escrime which T brass you used ? Thanks in advance.. Chris from Toulouse.
Old Nov 10, 2025 | 02:41 PM
michaelh's Avatar
Have a read of this thread of Shoreguy's. It may help you getting the tee and the octopus apart:
https://www.jaguarforums.com/forum/x...4/#post1931483
Old Nov 10, 2025 | 05:34 PM
Krotof1a's Avatar
Thanks a lot @michaelh for the ressource. I will make a try tomorrow.
Old Nov 17, 2025 | 07:06 AM
earny's Avatar
Hi, as you are from France you should also be able to find these - I took a 16-10-16mm T brass. 19-10-10 will probably also fit.
https://www.ebay.de/itm/315327549618...yABEgLB6PD_BwE
Best regards, Bernd
Old Nov 17, 2025 | 01:13 PM
Krotof1a's Avatar
Hello. Thanks for the link. I tryed the normal way but the NORMA connector broke. I then ordered a T brass that 3/4, 1/2, 3/4. Hope it will match....
chriswilliamdavis
XE ( X760 )
Jul 10, 2025 04:11 AM
Brizzy
Jun 7, 2024 03:02 PM
srmpf
Jan 19, 2014 01:48 PM
mikeeadyjr
Feb 8, 2012 07:11 AM
orca99usa
Aug 20, 2010 12:41 PM
