Cooling System Atmospheric Tank
Old Mar 11, 2021 | 09:08 AM
Bob Boyle's Avatar
Default Cooling System Atmospheric Tank
Is there any spec on the level of coolant that there should be in the atmospheric tank; mine is empty which doesn't seem right?
2003 XK8
Old Mar 11, 2021 | 09:39 AM
kstevusa's Avatar
Bob, fill level is to bottom of neck that cap screws onto. After filling, May want to drive auto parts store and have a pressure check to see if visible leak. It is to be at the level indicated at all times.
Old Mar 11, 2021 | 09:48 AM
xalty's Avatar
the overflow in the fender should be almost empty
fill the expansion tank almost to the top
Old Mar 11, 2021 | 09:49 AM
Bob Boyle's Avatar
Good advice, thanks..
Old Mar 12, 2021 | 04:08 AM
With a cold engine, this would be a typical level:
Old Mar 12, 2021 | 08:02 AM
Bob Boyle's Avatar
Thanks for this. Very good good guidance.
Old Mar 12, 2021 | 08:37 AM
fmertz's Avatar
What you want is to have enough "extra" coolant in that recovery tank so that when the engine cools off and brings coolant back in the system, you are not running out and sucking air in, even when parked at an angle. That advocates towards keeping a lot of coolant in the recovery tank.
On the other hand, the recovery tank has to have enough room so that when the engine is hot and pushes coolant in the recovery tank, it does not overflow. This advocates towards keeping as little coolant in the recovery tank as possible.
For my own car, I evaluate those arguments equally and kept the tank half full (once, during a upper mount replacement, when the liner was off). My take on it.
Old Mar 12, 2021 | 09:02 AM
Bob Boyle's Avatar
That makes a lot of sense to me. Thanks for your input.
Old Mar 12, 2021 | 10:14 AM
TropicCat's Avatar
I read a post on one of the other forums a little while ago that stated the atmospheric tank should be filled half way when cold. This is where I've set mine. (After I patched the hole in the bottom.)
Old Mar 12, 2021 | 10:44 AM
Bob Boyle's Avatar
Thanks for your comment, good advice.
Old Mar 12, 2021 | 04:30 PM
Jagvert2000's Avatar
Is the recovery tank ( in fender well) visible for inspection without removing the inner liner of the fender?
Old Mar 12, 2021 | 05:15 PM
Bob Boyle's Avatar
The only way to see this tank is by removing the liner which isn't good in my opinion. Out of sight out of mind isn't good if you're interested in the general health of your car.
Old Mar 13, 2021 | 07:01 AM
DavidYau's Avatar
Default O&DR has a good Youtube video on this
O&DR has a good Youtube video on the Atmospheric Tank. See below.
He made an easy modification in cutting a hole in the wheel arch for a visual inspection port.
Old Mar 13, 2021 | 07:05 AM
The X100 has a High Velocity/Low Capacity cooling system. Total capacity on the N/A is 9.5 litres and on the S/C it's 11.5 litres. I haven't measured the capacity of the Atmospheric Recovery Bottle but would think it must be about 4 litres or equivalent to one third of the total volume in the S/C system.
I can't find an absolute figure for the expansion of the specified coolant. However, the volume of water increases by about four percent when heated from room temperature to its boiling point so coolant must be similar. Therefore expect expansion of the coolant from cold to running temperature to be in the order of 0.5 litre. We're not talking massive volumes of fluid transfer from the Expansion Tank to the Atmospheric Recovery Bottle and back again as the engine heats up then cools.
It's the correct level in the Expansion Tank at cold that's important. The level in the Atmospheric Recovery Bottle isn't critical.
Old Mar 13, 2021 | 07:36 AM
Bob Boyle's Avatar
https://www.youtube.com/watch?v=IuCJ2X6NvjA&t=11s
Thanks for the link to this video it fully answers my question about the level and it looks like a simple modification that allows periodic inspection of the level.
Thanks for your help.
Old Mar 13, 2021 | 04:13 PM
astromorg's Avatar
To avoid cutting up the wheel-arch liner, you can view the tank any time through the gap between the A pillar and the open driver's door using a good torch.
Old Mar 13, 2021 | 04:21 PM
Bob Boyle's Avatar
I'm being given some really simple ideas concerning this question; I'll check this one out for sure.
Thanks..
Old Mar 16, 2021 | 10:28 AM
TropicCat's Avatar
On one of the other forums I saw a mod a guy made to the fender liner to put in a 'view port'. It amounts to drilling a large hole (with a hole saw) and plugging it with a rubber plug (like a grommet but with the middle filled with solid rubber. (Would be a good idea to find the plug first and size the hole accordingly instead of the other way around.) Looks like a worthwhile mod. I'm a little concerned about the plug blowing out under the force of water spray when driving in the rain. Not a huge problem since the only thing behind the fender liner on that side is the recovery tank but if the plug blows out hard debris (likes rocks and glass bits) can get in there and put a hole in the plastic bottle. I'm still going back and forth over this mod.
Just an idea.
Oh, and one more thought. You can pressure test the cap. IF you have the proper adapter. I know, I know, you have to buy the stupid Jag pressure cap tester adapter. But if you can't figure out what's going on it might be worth it.
Old Mar 16, 2021 | 11:18 AM
Bob Boyle's Avatar
Just an idea.
Thanks for your input, I appreciate it. The interesting thing about this thread is the tip I got from astromorg resolved the ability to inspect the level. Sometimes the obvious isn't obvious.
blackwolf560
Aug 29, 2021 12:29 PM
BKSinAZ
Jan 25, 2021 10:45 AM
Xk646
Dec 15, 2020 09:06 AM
Bonzo
Sep 17, 2020 07:15 AM
The Wizard of BC
Nov 5, 2013 07:49 PM
