Cup holder flap
Old Aug 12, 2020 | 01:08 PM
alanroberts50's Avatar
Default Cup holder flap
It started just popping open at the slightest bump or even when I put my arm on the armrest. The catch looks to be ok so is there a trick? Is it a matter of bending the flap somehow? Trying not to break it!
Old Aug 12, 2020 | 01:15 PM
Johnken's Avatar
Yes heres 1. Watch the movement of the latch release button as you close it, as it releases. You'll quickly see that you can stuff a small piece of clear folded plastic under the rear side to keep latch button in up position, providing greatest latch power.
John
Old Aug 12, 2020 | 02:03 PM
rothwell's Avatar
A more elaborate fix is to disassemble the lid and shim the cup holder mechanism with washers to reduce the gap between the flap and the lid/button. I did that and it works well.
Old Aug 12, 2020 | 04:39 PM
christ's Avatar
Gorilla glue it shut. You can't use the cupholders for anything useful anyway.
Old Aug 12, 2020 | 06:47 PM
giandanielxk8's Avatar
I actually commit the sin of using my useless cupholders whenever I end up at a drive-thru. To make sure the contents of the drinks are not spilled, I keep my left hand on the steering wheel while I secure the cups with my right hand. Alternatively, my passenger, if available, secures the cups on the cupholder while I drive. It's not ideal, but it works in a pinch.
Old Aug 12, 2020 | 09:01 PM
crbass's Avatar
Exactly. Where are you to put your right hand? Only two choices. Shift knob, but then you might want to try to shift, jamming your left knee. Other choice is on the cup, protecting your knee and providing opportunities to test/refine your fine motor control in the bends.
Old Aug 13, 2020 | 09:28 AM
"Jamming your left knee?" Am I missing something here? I just keep the hand right hand on the cup. I can drive well enough with only my left hand.
Old Aug 13, 2020 | 09:35 AM
crbass's Avatar
Phantom clutch.
uncle jim
Jul 12, 2016 09:32 AM
marvin.d.miller
Jul 20, 2015 04:13 PM
darren-talbot
Interior
Feb 17, 2013 07:49 PM
rocklandjag
May 14, 2010 03:13 PM
mtotrainer
Jan 20, 2009 05:48 PM
