Curious locking issue
Old Jul 25, 2024 | 07:59 AM
Tusk's Avatar
Default Curious locking issue
Hello all. I've recently acquired a 2000 US spec XK8 convertible. The car came without a keyfob, but with three (!) working keys. I got a replacement 315MHz fob from the US and programmed it and it sort of works. However, when I unlock the car with the fob, only the drivers side will open. Oddly, when i use a key to unlock, both doors will open, the same when unlocking from inside, so it's not an actuator issue. Is it a standard 'feature' on US spec cars that only the drivers door will unlock with the fob and can it be removed, preferably without the aid of a Jaguar dealer?
Old Jul 25, 2024 | 08:32 AM
JimmyL's Avatar
Talking Locking
With mine the driver's door will unlock with the first push of the (unlock) button, the second push will unlock the passenger door.
Old Jul 25, 2024 | 09:22 AM
Jon89's Avatar
^^ Same here....
Old Jul 25, 2024 | 10:00 AM
zray's Avatar
^^^ Identical on my 2002 XKR
Old Jul 25, 2024 | 10:43 AM
Tusk's Avatar
It never occured to me to try pressing twice. It works! Everyday is a school day :-)
I am positive on my former euro spec XKR a single press unlocked all doors.
Thanks, all.
Old Jul 25, 2024 | 10:59 AM
bladerunner919's Avatar
Thanks, all.
I'm sure you're right - my UK car is definitely a single press to unlock the lot.
Old Jul 25, 2024 | 03:54 PM
astromorg's Avatar
This is an extract from my wife's X type handbook.
Selecting single-stage or two-stage unlocking.
The procedure for changing from single-stage to two-stage unlocking, or vice versa, is as follows: • Press and hold the lock and unlock buttons on the key transmitter simultaneously for four seconds.
Note: The direction indicators will flash twice to confirm the procedure was successful. To revert to the previous condition, repeat the procedure described above.
I've tried it on my XK8, but with no success. It remains resolutely Single-Stage, but maybe its different over the Pond
Old Jul 25, 2024 | 05:01 PM
motorcarman's Avatar
WDS or IDS can choose the locking configuration.
When I did a PDI at the dealer I asked the sales guy if the customer would like to choose the features that were configurable.
It was a ONE-TIME offer because the dealer would charge the minimum shop time when they wanted things changed.
They could come into the shop and we would go through the list of choices.
File Type: pdf
Old Jul 26, 2024 | 09:03 AM
Tusk's Avatar
Didn't work on mine, either. I think in 2000 they switched over to the Ford type remotes, presumably it works on those later style modules.
mikesbaron
Mar 6, 2023 08:48 AM
UnpaidIntern
Nov 3, 2022 03:12 AM
Godspeed
Apr 30, 2019 08:44 AM
liljepa
Apr 19, 2018 08:08 AM
magmedia
Dec 18, 2015 03:16 PM
