Direct Replacement parts - Ford or Lincoln catalytic converters?
Old Jul 11, 2013 | 08:37 AM
Max's Avatar
Max
Default Direct Replacement parts - Ford or Lincoln catalytic converters?
Does anyone know if any of the later model Fords or Lincolns catalytic converters are direct replacements for Jaguars, specifically the right bank, passanger side, of a 2000 XK8?
Thanks.
Last edited by GGG; Jul 11, 2013 at 06:17 PM. Reason: edit thread title to add detail
Old Jul 11, 2013 | 06:20 PM
I've edited your Thread Title to try to prompt a response.
74 Views as I write and no replies. Surely someone knows the answer even if it's 'NO'....?
Old Jul 11, 2013 | 07:24 PM
Max's Avatar
Max
Thank you, Graham.
Old Jul 12, 2013 | 09:26 AM
K.Westra's Avatar
I'm going to doubt that any of the Ford/Lincoln parts would work here since it is fairly tight for space, but before you consider OEM Jaguar, try Nameless Performance. You can get some very nice units that flow better than OEM and for less money. I've heard the wait time can be long though.
Old Jul 12, 2013 | 12:24 PM
Max's Avatar
Max
Thanks, Keith, I will check them out.
Old Jul 15, 2013 | 05:51 AM
xenophobe's Avatar
It's unlikely. While the engine blocks are similar and share many components, they're more different than similar.
Old Jul 16, 2013 | 08:10 AM
Max's Avatar
Max
Thanks, xenophobe. It appears Nameless Performance and OEM are the only options, if the Nameless downpipes with cats for the XKR will fit.
Old Jul 16, 2013 | 09:12 AM
Rey's Avatar
Rey
My personal experience with replacing OEM cats with aftermarket cats is limited to General Motors LS engines, which are larger in displacement than any current Jag motor. Found that a much smaller aftermarket cat fit just fine and performed well for 90K miles.
With that experience I think you could probably fit a Ford/Lincoln cat from their "Jaguar-like" motors. But you will have to confirm fit from the general outside dimensions. This is critical. It probably will not be a "drop-in" fit. That's too much to hope for. I think then that a competent exhaust shop could work up a fitment, cutting in a new cat to your existing inlet/outlet connections..
Nameless Performance's cats are simply aftermarket cats with mounting connections to fit particular Jaguars. In my judgement, they are not exotic.
My guess is that Ford/Lincoln or quality (note "quality") aftermarket cats will pass any sniff test; but, beware of California which prohibits any change to OEM.
Old Jul 19, 2013 | 10:06 AM
Max's Avatar
Max
Thanks, Rey,
That opens up a wider selection to check out.
BrentGardner
29
Dec 16, 2024 12:13 AM
1100me
Aug 27, 2020 11:37 PM
RaceDiagnostics
Dec 11, 2015 10:12 AM
martybmw
Aug 31, 2015 10:15 PM
innzane
Aug 26, 2015 08:41 PM
