Door Arm Rest - Recover?
Old Mar 27, 2022 | 05:17 PM
scottatl's Avatar
Default Door Arm Rest - Recover?
Has anyone recovered the door armrest? Mine is worn out so dying would not help.
Old Mar 27, 2022 | 07:05 PM
rothwell's Avatar
I would try to find a matching panel from a RHD car in the UK. The passenger sides always seems to have far less wear.
Old Mar 27, 2022 | 07:22 PM
scottatl's Avatar
I just looked at the UK ebay based on your suggestion and found a company that makes them. Anyone every use JF Customs?
Link to UK eBay
Old Apr 3, 2022 | 10:54 AM
Edloke's Avatar
Mine were about the same. I used SEM Color Coat #15003 which a perfect color match.
Color Coat is a spray for vinyl and plastics, comes in a rattlecan. Easy repair, commonly done by auto upholstery shops.
Can be bought online or at automotive paint shop.
Old Apr 3, 2022 | 12:01 PM
scottatl's Avatar
Is it a dye or also a solid crack fix?
Old Apr 3, 2022 | 02:41 PM
Edloke's Avatar
I do not think it is either. It is defined as a flexible paint specifically made for upholstery work, and will cover the unsightly armrest to a livable appearance standard for an investment of $18.
I have used this stuff on seats, door cards, etc. It wears like iron.
My latest use was to resurface the leather on my 99 XK8 steering wheel, which was discolored and scratched from 23 years of driving. Visit any local auto upholstery shop, and you will find they stock the full color assortment for minor touchups.
Old Apr 3, 2022 | 02:46 PM
Edloke's Avatar
Scott, I will be back in Highlands in late June and would welcome you to my house to use my material. A 2 hour drive from Atlanta.
It is recommended the surface be very clean. SEM makes a cleaner/surface prep for this.
Old Apr 4, 2022 | 01:42 AM
Pistnbroke's Avatar
Mine were exactly the same and now look new .. Get a can of cream coloured spray paint and a very small brush.. Squirt into the can lid and then touch up the bad areas ...takes about 3 coats as it soaks in ..easy and cheap
pcolapacker
Jun 29, 2021 09:42 PM
Steerforth
Jun 25, 2021 05:03 PM
my2000xj8
Jan 12, 2018 04:12 PM
vdpnyc
Feb 3, 2014 05:43 PM
JackJ
Sep 29, 2012 09:46 PM
