Driveline Clunk
Old Dec 22, 2023 | 02:02 PM
giandanielxk8's Avatar
Default Driveline Clunk
Today I just noticed a clunk that happens only when accelerating from a stop or near stop with about 40% throttle or more. No vibrations can be felt, it cannot be reproduced when the vehicle is already in motion and is not suspension-related. It seems to be coming from somewhere in the driveline. It almost sounds like it's beneath the driver's seat. No issues with the transmission. That shifts beautifully.
I'm thinking of either one of the U-joints for the half shafts, the driveshaft, or the jurid coupling. Last time I was underneath the car I noticed the rubber of the jurid coupling was beginning to dry rot, so that is my first suspect. When I get under the car, what other things should I check?
Old Dec 22, 2023 | 07:53 PM
RJ237's Avatar
Transmission mount
Old Dec 22, 2023 | 08:00 PM
Originally Posted by RJ237
Transmission mount
Looked fine last I checked and I replaced it last year, but it's certainly possible. I have an RMS leak that I haven't gotten around to fixing. The oil may have destroyed the mount.
Old Dec 22, 2023 | 09:11 PM
motorcarman's Avatar
Things we did at the dealer years ago.
Not everything in your VIN range but things to consider.
File Type: pdf
File Type: pdf
File Type: pdf
Old Dec 23, 2023 | 06:25 AM
STLTHMSTA's Avatar
Wow! Talk about archives. Thanks Motorcarman, I printed those out for reference. I'm getting quite a file of all the info found here on the forum. TM
Old Dec 23, 2023 | 06:55 AM
Wow! Great info! I'll check those out when I'm under the car and if anything seems amiss, I will do the TSBs as well.
Old Dec 25, 2023 | 12:04 PM
galearmstrong's Avatar
My 1999 does the same thing once it’s up to temperature, cold is fine.
Discovered my issue was RPM once it warmed up, idle speed would drop to around 550 and trans seemed to slip back into neutral. Accelerating it would slam into first and take off, ease into the throttle also worked fine. Putting my left foot on the brake and bringing the RPMs up to 650 then accelerating there was no clunk. I need to find a way to get my warm idle up 100 RPMs.
Old Dec 25, 2023 | 12:27 PM
cjd777's Avatar
Easy job to adjust the accelerator cable, might even help with response.
Old Dec 25, 2023 | 12:39 PM
Cable is tight….adjusting gets the cold idle too high.
AngusJam
Dec 14, 2021 12:42 PM
silversurfer1221
Oct 3, 2021 03:31 PM
giandanielxk8
Jun 28, 2020 08:28 PM
Mueller
Dec 22, 2016 07:59 PM
jfleming
XJ40 ( XJ81 )
Mar 8, 2016 06:27 PM
