Engine Fault, Stability Fault, Traction Fault
Old Apr 30, 2018 | 07:52 PM
ooblick's Avatar
Default Engine Fault, Stability Fault, Traction Fault
Haven't driven the car for a while. Charged it up, and on starting got the trifecta of faults and the engine is running really rough. Any thoughts before I have it towed to the shop?
Old Apr 30, 2018 | 09:10 PM
zray's Avatar
try another battery, and run the fault codes.
Z
Old Apr 30, 2018 | 09:25 PM
ooblick's Avatar
Thanks! are there any fault code tools available for the Mac and/or iOS? I was unable to find anything when I looked.
Old May 1, 2018 | 08:10 AM
avern1's Avatar
Check ebay and amazon for the ELM scan tool. You can then download the Torque APP for the I-Phone. They work quite well, are reasonably cheap and can read in real time running mode.
Old May 1, 2018 | 08:44 AM
ooblick's Avatar
THANK YOU! Shall do that today.
Old May 1, 2018 | 09:42 AM
ooblick's Avatar
Who knew my crappy old "Automatic" app and plug in would actually work on the XK8?
Engine codes:
P1368
P0358
P0355
P0353
P0352
Old May 2, 2018 | 10:09 AM
ooblick's Avatar
Bought a new battery yesterday, and will try that ASAP. Thanks for the help, folks. I will report what happens.
Old May 2, 2018 | 10:32 AM
RJ237's Avatar
Those are indications of ECU failure in a 97. You can switch a couple of the coils from bad cylinders to good, and if the faults don't move it's the ECU.
I have used ASI in Tennessee as have many others.
http://www.autoecu.com/
Old May 2, 2018 | 03:53 PM
ooblick's Avatar
Yeah, the battery switch did nothing. I will need to investigate further.
Old May 2, 2018 | 04:23 PM
scottatl's Avatar
99% chance you will need this and that will fix it. I had A.S.I. do the rebuild and it took them two times and were a pain to work with but it is working now.
https://www.autoecu.com/throttle-bod...epair-service/
Old May 3, 2018 | 08:38 AM
ooblick's Avatar
We're going to pull it and send it in for rebuild. It's only money, right? :-).
Old May 3, 2018 | 12:32 PM
RJ237's Avatar
They charge about $55 to test, which is applied to the repair cost if they can repair it.
Old Aug 4, 2018 | 06:09 PM
ooblick's Avatar
I know it's been awhile, but I've been super crazy busy with a new job, health issues, you know the drill. In any case, pulled the ECU, sent it to ASI, fast turn around, re-installed and started it up, got traction and stability faults, and engine coolant low. I've had a problem with the engine coolant low warning since perhaps year 3 of ownership, so I watch the temp gauge like a hawk. Traction and stability faults I figured were the ole ABS issue. I let it run for awhile, shut it down, plugged in the engine analyzer, restarted, and traction and stability faults went away. Engine coolant light remained, but ZERO ENGINE FAULTS! I'm on the right track!!!
Old Aug 5, 2018 | 06:49 AM
reb1999's Avatar
Yes I agree, a slightly weak battery will set off these codes. Traction control is the most common. I try to run my Jag at least once a week and take it for a bit of a spin which seems to keep everything at bay. If the condition happens often I would change the battery. Old days we could change the acid in the battery to give it new life. Newer batteries which are sealed anyway seem to short out a between the plates at the bottom of the battery. I guess a bit of corrosion builds up. We are in a disposable world. Good luck ,Rich
Old Aug 5, 2018 | 01:58 PM
ooblick's Avatar
Thanks, Rich. It's a brand new battery, so I'm afraid I'm in the re-soldier the ABS world now. We did clean all of the sensors, checked the resistance, checked the fuses, etc. It's intermittent, which gives me another clue, but more often than not I get those warnings. So it looks like I'm going to have to bite the bullet and make the attempt to pull the module, crack the case (or use the drill technique....carefully) and try the re-soldier. However, the great news is I can drive the car carefully so I can get it inspected and the emissions done so I can re-register it. That's a start. Future fun will include reconditioning the carpets and headliner, then I'm looking at the plasti-dip stuff for paint, since my paint is unsalvageable, sadly.
Old Mar 22, 2019 | 02:40 AM
Chasen's Avatar
the picture is unclear
Old Mar 23, 2019 | 08:23 AM
ooblick's Avatar
I was able to clear all those fault codes, but now it's having a transmission fault, so I'm expecting I may have to give up on Brutus and sell him. I am sad.
Old Mar 23, 2019 | 09:23 AM
michaelh's Avatar
Don't give up on him just yet.. What codes is he throwing at you this time? What symptoms are you getting?
Old Mar 25, 2019 | 07:17 PM
ooblick's Avatar
I wasn't getting any engine codes, but was getting a red light and Transmission Fault indicator, and it runs poorly. I can check for anything specific if if you have any ideas. I haven't done the resoldiering yet, so still getting the stability and traction faults, but the replacement computer worked for the engine faults.
Old Mar 26, 2019 | 04:30 PM
michaelh's Avatar
Try to resolve the ABS issues as there may be a connection with the trans problem (they do talk to each other). Can you get the car somewhere that can read the Jaguar codes? It will help you with the ABS diagnosis and may give you some more information as to why the trans is complaining.
Do the messages appear during the startup sequence or only when driving?
Good luck.
