Finally Programmed Garage Door Opener
Old May 14, 2026 | 10:09 AM
LMG's Avatar
LMG
Default Finally Programmed Garage Door Opener
For programming my Lift Master garage doors, I have tried every conceivable permutation of the various instructions and tips posted here over the years with no luck.
Finally gave up and bought this
Repeater Kit Repeater Kit
, which worked right away. Figured I'd post the success in case somebody else is annoyed with having a remote clipped to the sunvisor.
The instructions for programming the kit are essentially identical to the commonly found recommendation to program the car Homelink with a remote first, then with the door opener. Why that never worked for me, I don't know.
Old May 14, 2026 | 10:34 AM
dibbit's Avatar
Presumably your Lift Master doors are too new to work with the ancient electronics in the Jaguar and that module works as a bridge between old and new.
Old May 14, 2026 | 06:36 PM
motorcarman's Avatar
My Lift Master/Chamberlain 3/4 HP chain drive made in 2007 circuit board 'crapped-out' so I sent it to guy to repair.
It will retain 8 transmitters of old Jaguar tech so I had to keep it going!
Cost $50 to repair it so I still have all the openers functioning.(I hate change when I don't want it)
Old May 14, 2026 | 07:01 PM
LMG's Avatar
LMG
Eight Jags, you live a life the rest of us can only dream of!
Old May 14, 2026 | 08:07 PM
Technically only 6 Jaguars are configured to the GDO and TWO handheld transmitters relegated to the Farm Trucks.
JarodL
Apr 21, 2025 06:25 PM
lrbrowns
Sep 11, 2019 08:59 PM
ronald4313jm
Sep 26, 2015 07:57 PM
Glendoramike
General Tech Help
Aug 28, 2013 12:18 PM
Venumb
Nov 14, 2008 06:10 PM
