Flooded Engine cylinders
Old Dec 10, 2015 | 06:46 PM
Rick Vaughn's Avatar
Default Flooded Engine cylinders
Good evening, my 97 jag lost all compression from fuel drenched cylinders, does anyone know what the cause would be? The last time we removed the spark plugs, injected 15 squirts of oil into each cylinder and started the car, yesterday, I injected 15 squirts of oil and it almost started, I hope someone has experienced this and knows the solution, Thank You
Old Dec 10, 2015 | 07:06 PM
test point's Avatar
Cylinder wash in the early years of the XK8/R was a Jaguar provided feature for a couple years. There are a number of discussions on the subject.
Start here:
JagRepair.com - Jaguar Repair Information Resource
Old Dec 10, 2015 | 07:12 PM
Thank You, I did find a thread that expians why it happened and how to start the car again, have a great evening
Old Dec 10, 2015 | 07:37 PM
Mikey's Avatar
The solution is to not start the engine without a plan to let it run for at least a few minutes, preferably longer.
Old Dec 10, 2015 | 07:51 PM
Gus's Avatar
Gus
You should add a can of Restore to your oil the next oil change.
Gus
www.jagrepair.com
Old Dec 11, 2015 | 08:23 AM
Default Coil Pack Plug in
Thank everyone for the update on my flooded engine problem, I just changed the oil with full synthetic oil, I am now concerned as to gasoline in the crankcase washing out the engine bearings, Gus, you mentioned a can of restore, what will adding this do to help??I am not familar with the additive? Also, I broke one of the coil pack connectors, do any of you have a parts car in the US, so I could purchase a connector? I also could use a complete windshield resevoir? Thanks again
Old Dec 11, 2015 | 10:27 AM
Gus's Avatar
Gus
This link will help you better understand the product. It has been used by many on this forum to help prevent cylinder washing.
Link Engine Restorer
Old Dec 11, 2015 | 05:11 PM
Rick - check with Autobahn kid - he is in Florida and has one or 2 he is parting out. He is great to work with
NS2000XKR
Nov 28, 2015 10:06 AM
projectjag
Nov 22, 2015 12:35 PM
96jaguarxj6
Nov 21, 2015 11:29 PM
Rhett
Nov 21, 2015 10:23 PM
Jacob Greer
Nov 21, 2015 03:32 AM
