Found my rear suspension clunk
Old Apr 19, 2025 | 10:40 PM
giandanielxk8's Avatar
Default Found my rear suspension clunk
Found the cause of my rear suspension clunk. Scary to think I was driving like this. They only lasted 4 years, about 15k miles.
Here’s a video of what I am talking about:
I just ordered a set of these. Has anyone had experience with them?
Polyurethane Rear Upper Shock Bushings from Simply Performance
Old Apr 20, 2025 | 12:58 AM
baxtor's Avatar
The Desintegrating Foam Mounts Strike Again
l Don't know about those in particular, but l assume they are much the same as the rear kit l make.
only note l can make is regarding the damper mount bushes thickness. If OEM thickness you will find the top nut will require just a little more torque than listed to seat them correctly. This is due to the increased shore hardness in comparison to the factory "foam" and is only an issue on CATS cars because of the lower torque listed for the top nut.
l reduced the thickness of my own slightly to match the factory torque spec requirement in the seating of them.
Old Apr 20, 2025 | 07:07 AM
Jon89's Avatar
Gian,
I would cancel that set you ordered and obtain a set from baxtor (Steve)....
Old Apr 20, 2025 | 11:24 AM
Originally Posted by Jon89
Gian,
I didn’t know he was making them for the rear as well. I just shot him a PM. I would definitely prefer his.
Old Apr 20, 2025 | 11:48 AM
Kuddlesworth's Avatar
I think those are shore 60 like their front mounts.
Old Apr 20, 2025 | 03:07 PM
2003RagJag's Avatar
In the Puerto Rico roads it most make a horrible rattle....
Old Apr 21, 2025 | 03:54 PM
Gian,
I was able to cancel the order. I’m getting Steve’s mounts instead.
I’m guessing that’s too soft?
It wasn’t as bad as you would expect. I thought I had a loose item in the trunk or a loose bumper cover.
Old Apr 22, 2025 | 11:10 AM
Shoreguy's Avatar
Veteran: Air Force
Hey Gian
When I changed over to Wayne's front mounts I figured it was a good time to do the rear mounts. Wayne had me contact, Steve Baxtor, for the rears which are on par with Wayne's mounts probably because they worked/formulated them together. I honestly couldn't be happier with the quality and results. Steve, is a great guy to deal with good luck.
Old Apr 22, 2025 | 11:48 AM
No I think it should be fine. I think baxtors are shore 60? So not much difference. Should help getting the CATS shocks torque on the nut correct maybe.
Old Apr 22, 2025 | 03:45 PM
Well in any case, I was able to cancel the purchase with Simply Performance and bought a set from Baxtor.
I prefer supporting what a fellow forum member has developed.
Old Apr 22, 2025 | 11:35 PM
brinny's Avatar
Might need a set of these myself. Do we know the cost?
Old Apr 23, 2025 | 06:38 AM
Steve (Baxtor) priced them at $160 AUD, which is around $108 USD. Quite reasonable in my opinion.
Rishi
Mar 30, 2025 08:18 AM
Turko
Jan 23, 2025 04:46 PM
Paulo Sérgio
Dec 31, 2020 04:39 AM
stuart goodwin
Sep 28, 2016 11:14 AM
pab
Dec 6, 2014 03:10 PM
