front ball joint / seperator
Old Dec 14, 2015 | 09:22 AM
jamdmyers's Avatar
Default front ball joint / seperator
Question, I'm pulling the front apart to replace bushings etc, I'm trying to remove the lower ball joint using a Hfreight claw style bj clamp, I find the bj shank it too wide to fit the claw in, I'm considering grinding the jaw a bit wider but wanted some input first.
2nd question: the rotor shield appears to be seated within this balljoint shank, when pressing the new one in did you do this or just cut the tab on the shield ?
Old Dec 14, 2015 | 01:15 PM
RaceDiagnostics's Avatar
I used one like this. It was very difficult to break free, it took a lot of torque, a lot of heat and a big hammer.
The heat shield retaining loop sits over the shank and will stay in place.
Old Dec 14, 2015 | 01:49 PM
Gus's Avatar
Gus
Tap the push point with a hammer gently as you tighten.
Gus
www.jagrepair.com
Old Dec 14, 2015 | 02:12 PM
dieseldoc's Avatar
Just hit the area where the ball joint goes thru the spindle with a big hammer, should just pop free. the ball joint is tapered just need to shock it free.
Old Dec 14, 2015 | 02:19 PM
Brutal's Avatar
^^^exactly, and if youve been drinking or cant hit a lick at a snake then use 2 hammers so you dont miss and damage something else
Old Dec 14, 2015 | 07:14 PM
motorcarman's Avatar
Or use a long barrel air hammer and a hammer bit (NOT A POINTY BIT).
bob gauff
Old Dec 14, 2015 | 11:18 PM
plums's Avatar
easy to tell who works flatrate 'round these parts
Old Dec 15, 2015 | 02:14 AM
jamdmyers's Avatar
Thank you all for the replies,
I used the grinder to 'open' the clamp mouth, it only needed 1/32" more, similar to the one shown above it now fits in.
And I misunderstood the shield, it will fit on re-assembly.
Tijoe
Dec 10, 2015 09:43 AM
XxSlowpokexX
Dec 3, 2015 05:18 PM
Fstbmw1
Nov 27, 2015 03:08 PM
Alan DeFend
Nov 22, 2015 12:47 PM
iownme
Nov 19, 2015 02:27 PM
