Front seat remove
Old May 26, 2018 | 04:55 PM
Ruger's Avatar
Default Front seat remove
I have a 2000 xkr and the seat stopped working and i can't remove it as the seat it forward and i can't get the bolts out. Hopi g there is some release to dis engage the motor.
thanks
Old May 26, 2018 | 05:14 PM
Welcome to the forum Ruger,
I've moved your question from General Tech Help to XK8/XKR forum. This is the place to post questions about your model.
Old May 26, 2018 | 05:31 PM
avern1's Avatar
The most common problem for the seat to stop operating is the seat module. If you look under the front of the seat you should see 2 bolt heads. I think from the last time I did it they are 10MM. Remove the 2 bolts and the seat module can be removed. Do the same thing on the passenger seat and then plug the module from the passenger seat into the driver seat plugs. You should now be able to move the seat.
If that works then your seat module needs to be repaired. Let me know it worked and I will dig up the phone number for a great fellow in California that repairs them. He has done 100's for the forum members.
Old May 27, 2018 | 05:20 AM
Here's the Seat Module fixings on a 2005. The 2000 is similar:
There's not a lot of room to work beneath the seat so it helps to know what you're trying to find.
Old May 27, 2018 | 06:13 AM
Orthodixie's Avatar
Recently had the same issue. Before you remove the seat make sure the connection(on the driver side it is in the right side of the seat) hasn't been dislodged. I moved mine too far forward and it quit. Reseating(pun intended) resolved the issue.
Old May 27, 2018 | 05:47 PM
Ruger's Avatar
Ok I switched the seat module and still nothing, I did check the driver's side seat module fuse in the facia side fuse panel and no power with the key off and I think there should be power to that fuse.
I'm going to try to check the right side of the seat for the connector to be pulled out.
thanks everyone for your help
Joe
Old May 27, 2018 | 06:04 PM
Ruger's Avatar
Sorry I do have power to the 20 amp fuse the bolt in that fuse panel is not a good ground....
Old May 28, 2018 | 01:26 AM
CaleyThistle's Avatar
You could try disconnecting the yellow multiplug going to the seat, spray with contact cleaner and reconnect. I occasionally have to do that with mine to get it to work.
Old May 28, 2018 | 03:53 AM
Is Fuse 8 (5 amp) in the same box OK? It's for the driver's seat switchpack.
Old Jun 4, 2018 | 10:30 PM
MidnghtOwl's Avatar
I recently fought both seats that had frozen motors. (2000 XKR). Before I figure out my solution I had hot wired the motor with a direct battery lead proving it was dead. it's fingertip work but you can get the white plug from the motor harness free and tap the two pins to see if the motor is working). If you can "manually" get the motor to move, then you can fairly easily remove the seat. In my case, I had to unbolt the seats from the track system because the motors were rusted solid. (ratcheting box end and a t40 bit) then start the rebuild.
Good luck and keep us posted!
ExcelsiorZ
Feb 7, 2019 08:58 PM
blasgg
Nov 19, 2017 06:34 PM
AfricanJag
Nov 25, 2014 12:46 AM
Flying Finn
Jul 17, 2009 10:31 AM
bojangles
Oct 28, 2006 09:27 PM
