Front Spring Replacement on XK8 convertible
Old Oct 5, 2013 | 10:57 AM
tosaman's Avatar
Default Front Spring Replacement on XK8 convertible
This topic may have been discussed before, however, I'm thinking about replacing the front springs on my 2002 XK8 convertible. The shop said I was about 1-1/2" low in the front end. I don't like the "rake" that the car has due to the weakened front springs, plus the damage that keeps happening to the lower plastic shield every time I go out a driveway. I only want stock replacements and am not interested in the "lowering" spring sets that others have talked about.
Where can I get unused stock replacements (assuming that's possible)? RockAuto seems to have them, but they're supposedly only for cars that were sold in Europe. Is there really any difference in the springs that are on cars sold in Europe versus the US?
Thanks for any help.
Old Oct 5, 2013 | 11:40 AM
millenia man's Avatar
Hi,
I ordered a pair of replacement front springs for my 1999 xk8 convertible from Jaguar XK8 and Jaguar XKR Parts and Accessories.
Dave Roch is the person I dealt with, very helpful fellow. Quick shipping. I was planning on installing them today, but the weather was crappy.
The cost was about $425.00 with shipping.
Here is the spring url.
Front Shock Absorbers And Spring Parts | Jaguar XK8 and XKR Parts and Accessories
Old Oct 5, 2013 | 02:41 PM
OregonJag's Avatar
Got my springs from Nalley Jag (a former sponsor of the forum). The price on the stock Jag springs was really good at <$300 shipped. That was last summer. Do a bit of shopping around for the best price. Here's the difference it made --> https://www.jaguarforums.com/forum/x...se-lift-76446/
As I mentioned in the Nose Lift thread, the springs are spec'd and referenced to VIN number so make sure you get the right ones for stock ride and height.
You will want to replace the upper spring pads at the same time. They are shot at over 10 years old.
Mike
Old Oct 5, 2013 | 02:56 PM
TreVoRTasmin's Avatar
You're positive it just isn't bad upper mounts? If they have sagged a bit you can also get spacers fairly cheap that should work nicely on the xk8 set up.
Old Oct 5, 2013 | 03:15 PM
RJ237's Avatar
I'm interested in adding spacers when I replace the mounts. Do you know where to get them?
Old Oct 6, 2013 | 01:17 PM
Just about any speed shop should be able to get them. You just need the inner and outer diameters. Could go either on top or bottom on the xk8 I'd suspect. Here is an example.
Daystar KJ09108BK Comfort Ride 3/4" Lift Coil Spring Spacer Kit - 4 Piece : Amazon.com : Automotive Daystar KJ09108BK Comfort Ride 3/4" Lift Coil Spring Spacer Kit - 4 Piece : Amazon.com : Automotive
A good machine shop could make 'em but that would probably cost more.
Old Oct 6, 2013 | 06:03 PM
tosaman's Avatar
Thanks for all the info -- from the responses it appears that the springs are the same regardless as to where the car was sold (Europe vs. US).
Old Oct 6, 2013 | 08:44 PM
philhef's Avatar
I've been told both springs don't usually go out at the same time. It's more in the bushings. And mounts. Any truth to this!
I'm in the same boat, needing to get the front raised and the rear seems too high!
kurtomatic
Feb 12, 2024 06:58 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
mhamilton
Sep 15, 2015 05:13 PM
aquifer
Aug 29, 2015 04:54 PM
Mr.B
Aug 28, 2015 02:14 AM
