Fuel Filter replacement question - RESOLVED
Old Apr 5, 2016 | 11:26 AM
kreyszig's Avatar
Default Fuel Filter replacement question - RESOLVED
so - stupid question most likely, but if I change the fuel filter with a full tank, should I expect much in the way of leakage?
Last edited by GGG; Apr 13, 2016 at 12:48 PM. Reason: Add 'RESOLVED' to thread title
Old Apr 5, 2016 | 12:09 PM
Jon89's Avatar
Very small amount of fuel leakage when I changed my wife's XK8's fuel filter in March 2015. The car probably had half a tank of fuel at the time. Have a catch pan handy before you pull the lines, though....
Old Apr 5, 2016 | 12:38 PM
DevonDavid's Avatar
+1 on Jon89
Don't do it just after the engine has been running OR release the pressure with the schrader valve in the engine compartment first. After that, it's just the fuel in the pipes that will run out through gravity so not much more than a spoonful or so.
But - even a spoonful in your right eye can be uncomfortable, so have some old cloths or paper towels handy to catch the drips !
Old Apr 5, 2016 | 11:30 PM
Johnken's Avatar
Or you can pull the feul pump fuse while idling to relieve pressure.
Old Apr 5, 2016 | 11:42 PM
NBCat's Avatar
Have a container ready to place the used filter in as many jurisdictions have regulations on the disposal of used filters containing fuel or engine oil. There is also the danger of fire or explosion from the used filter depending on how it is stored.
Old Apr 6, 2016 | 03:33 AM
kreyszig's Avatar
thanks all. it's been sitting for months but I'll use the schraeder valve just to be sure. much obliged
Old Apr 9, 2016 | 01:39 PM
Sqeeter91's Avatar
It's also alot easier if you remove the left rear tire. Access is much easier. Did mine in about 20 minutes.
Old Apr 13, 2016 | 03:31 AM
kreyszig's Avatar
thanks everyone - it was super simple.
KayScotts
May 8, 2016 04:16 PM
tigger
Apr 2, 2016 08:56 PM
Jagdude
Apr 2, 2016 07:47 AM
Greencar89
Apr 1, 2016 05:30 PM
Ron Ho
Mar 31, 2016 11:41 AM
