fuel issues with codes
Old Oct 29, 2008 | 09:51 PM
2000blackxkr's Avatar
Default fuel issues with codes
yesterday i was driving home from work and got a check engine light with a restricted performance.
pulled codes
P0175 - bank b to rich
P0172 - bank a to rich
it was running really ruff. after a few minutes. the restricted performance went away and seemed to run normal but with the check engine light on.
then when i got home and hoped out to open the garage door "opener is broke". when it was idling the restricted performance came back on.
from reading alldata it says that its possible causes are -
blocked air filter - just replaced it 1k miles ago.
Fuel system return blockage - dont think that likely.
fuel pressure regulator - i think this is most possible.
ECM receiving incorrect signals from one or more of the following
ECTS - dont know what that is
MAFS - checked that using Auto-ingenuity scanner - reading right on the money.
IATS - checked that using Auto-ingenuity scanner - seems to be steady
TPS - checked that using Auto-ingenuity scanner - right on the money, no fluctiations.
Ok, so do any of ya know ware to go with this?
Thanks again.
Old Oct 30, 2008 | 10:37 AM
hlgeorge's Avatar
Default RE: fuel issues with codes
This happened to me. I got a can of BG-44K fuel additive and added it to my fuel. Then drove the car for 300 miles on a trip. For the first 100 miles, I got the reduced performance and the CEL. After 100 miles it never happened again. I reset the codes and it has not returned. Also check your mass air flow sensor.
Old Oct 30, 2008 | 10:57 AM
ken@britishparts.com's Avatar
I use the 44k a couple times a year in all my cars. Very good stuff.
Old Dec 17, 2008 | 05:45 AM
GreenJewel's Avatar
ORIGINAL: hlgeorge
Where can you purchase BG-44K? [sm=icon_cheers.gif]
Old Dec 17, 2008 | 08:26 AM
Brutal's Avatar
THOSE CODES ON YOUR MODEL CAR IS ALMOST ALWAYS MAFS, TRY CLEANING IT, AND IF IT RETURNS REPLACE THE MAFS
Old Dec 17, 2008 | 02:25 PM
hlgeorge's Avatar
I get the BG-44K on ebay. Brutal is right on the MAFS, but if you clean it be sure to use a MAFS cleaner made especially for it. Other cleaners can damage the MAFS.
Old Dec 17, 2008 | 05:24 PM
Gus's Avatar
Gus
Ken,
If I recall you sell BG products at British Auto Parts.
Old Dec 21, 2008 | 01:32 AM
you can check there web site. http://www.bgprod.com/products/fuelair.html
i found out that my local ford dealer was also a authorised dealer of BG-44K
they wanted 40.00 for a can.
Old Dec 21, 2008 | 08:34 PM
Brutal's Avatar
the whole service kit doesnt cost but that......retail
Old Dec 21, 2008 | 09:51 PM
hlgeorge's Avatar
40 a can! A rip off. Check ebay.
Old Dec 21, 2008 | 11:16 PM
i didn't say i got it from them. i found it at another dealer in town for 15.00
Old Dec 22, 2008 | 09:42 AM
remosusa's Avatar
what MAFS cleaner is reccomended?
Old Dec 22, 2008 | 08:40 PM
i have heard so many different story's to that question. i like to use plain distilled water and a q-tip. then dry it off with a can of air.
But im sure some one will say im wrong! [8D]
Old Dec 24, 2008 | 06:53 AM
GreenJewel's Avatar
ORIGINAL: hlgeorge
Were did you buy the BG-44K? I've never heard of it and I can't find it in my area.
TY
Old Dec 24, 2008 | 11:43 AM
hlgeorge's Avatar
I have always bought my BG 44K from ebay.
toronadomike
Jan 22, 2026 10:13 PM
philwarner
Oct 4, 2024 01:37 PM
Bcrary3
Sep 12, 2021 05:41 AM
Bowman
Sep 3, 2015 03:17 PM
OkieTim
Sep 2, 2015 12:48 PM
