fuel tank capacity
Old Jul 12, 2019 | 06:39 PM
wymjym's Avatar
Default fuel tank capacity
Hi,
I went for a cruise yesterday and decided to return home rather than continue into town for fuel. Normally I fill up @ 1/4 tank but yesterday was different.
The yellow fuel light was on, pulled into the station this morning and put in more gasoline than I thought the tank's capacity was.
First thought, incorrect metering at the sattion but then...I figured I should ask those that know.
My filler clicked off at 16.389 gallons (us).
What say the brain trust? Was I on fumes and the tank holds this much or other?
thank you for your time
wj
Old Jul 12, 2019 | 07:07 PM
michaelh's Avatar
You were fine
Tank capacity is ~19.9 US gallons, ~75 litres or ~16.5 imperial gallons.
https://www.thecalculatorsite.com/ar...al-gallons.php
Old Jul 13, 2019 | 02:38 AM
Johnken's Avatar
The light goes on with 2 gallon left.
J
Old Jul 13, 2019 | 02:50 AM
You had plenty left.
The trip computer has a RANGE display function which calculates how many more miles you can travel on the remaining fuel. I rarely run a tank below half but discovered it's possible to go at least 7 miles more when RANGE reads zero after desperately searching for an open petrol station on a Winter's night in Yorkshire.
Old Jul 13, 2019 | 08:29 AM
marvin.d.miller's Avatar
Yes, when my range read zero I traveled another 6 miles to the next gas station....
Old Jul 13, 2019 | 09:07 AM
Johnken's Avatar
+1 on the range.
Old Jul 13, 2019 | 10:07 AM
wymjym's Avatar
Originally Posted by Johnken
+1 on the range.
thanks everyone...now I know for sure
wj
Old Jul 13, 2019 | 10:22 AM
Ungn's Avatar
Since I eventually plan to upgrade the fuel pump and am looking for an excuse, I put in 17, 18 or more gallons in mine all the time. Filling at 16 gallons is probably best for long term pump life.
86jag
May 12, 2023 07:06 PM
DJS
Sep 12, 2016 08:42 PM
Censport
May 3, 2013 05:47 AM
Daimler68
Aug 23, 2010 06:52 PM
SeismicGuy
Mar 12, 2010 10:58 AM
