Gearbox won't shift into park.
Old May 26, 2022 | 01:12 PM
Phil m's Avatar
Default Gearbox won't shift into park.
I would appreciate some advice from you kind soul's again.
I took the XKR for a drive and drink today but when I got to the garage to fill up the car would not shift in to park, this problem has not happened before.
The only thing I did different (project car) was cycle the gearbox in to 3rd and 4th gear while driving.
Any thoughts would be great?
Old May 26, 2022 | 09:25 PM
oldmots's Avatar
You may need to make sure the rotary switch on the side of the tranny is not broken.
Old May 27, 2022 | 08:31 AM
Phil m's Avatar
Is that easy enough to do and could you exlain it for me?
Old May 27, 2022 | 04:58 PM
Gus's Avatar
Gus
Is it the shifter lock that is preventing it from going into “P”? If that is what is taking place it might be the brake switch. Work the pedal a few times and see if goes into “P”.
Old May 27, 2022 | 05:30 PM
Phil m's Avatar
Yes Gus if the shifter lock is the black plastic plate within the J Gate, I've pressed the brake a lot and driven the car while cycling through gearbox but no luck.
Old May 27, 2022 | 06:07 PM
Smitty99XKR's Avatar
Default Gearbox
Hello
Yes I have experienced this problem from time to time in my 99 XKR. I found it happened after vigorous driving and I just let it sit in neutral for a while, to let the engine temperature and gearbox oil cool a little. Then I put my foot hard on the brake, revved the engine and let the revs go and it goes into park ok.
That worked for me, but you might need a gearbox oil change, I would consult a mechanic. They dont last forever whatever people say and can be a bit tempremental at high temperature.
Probably not a big issue but I would get it looked at sooner rather than later. Contrary to what they say, the early 5 speed auto boxes are very good but need looking after at high mileage.
Hope this helps mate
Smitty 😀👍
Old May 27, 2022 | 06:16 PM
Default J gate
PS .... if it is an early one like mine I probably wouldnt use the J gate anymore if I were you. It is a selection which puts strain on the auto gearing cogs and the system that was really not designed for that long term. Just a thought.
Old May 27, 2022 | 07:55 PM
Gus's Avatar
Gus
The ZF trans is electric and linkage that is driven by your shifter cable and that cable may need adjustment . This is a link to a TSB on how to adjust the shifter cable.
http://www.jagrepair.com/images/TSB/307-01-1.pdf
Old May 27, 2022 | 10:40 PM
zray's Avatar
the OP has a ‘99 XKR with the Mercedes transmission, not a ZF unit. But I don’t know if the referenced TSB applies to both transmissions ?
Z
Old May 27, 2022 | 10:44 PM
zray's Avatar
interesting …. Do you happen to have any documentation that could be linked to the comments ?
I would love to read up on any 722.6 transmission information. My knowledge of the Mercedes transmission is sadly lacking.
Z
Old May 28, 2022 | 03:11 AM
dibbit's Avatar
All of us with the 4.0 XKR have the Mercedes 5G-Tronic 5 speed gearbox, which was widely used across quite a few different brands and, as you say, has a very good reputation. The 4.0 XK8s use the ZF 5HP24 which had a design flaw causing premature A drum failure, hence its poor reputation from new. I think ZF updated the gearbox in 2001 and many people will have rebuilt their original gearboxes with the upgraded parts by now, but this is a problem the Mercedes gearbox never had.
Old May 29, 2022 | 03:49 AM
Phil m's Avatar
Thanks for the info Gus, do you know where under the car the transmission lever (illustration 2) is?
Old May 29, 2022 | 03:51 AM
Phil m's Avatar
Also thanks to all for the advice and comments.
Old May 29, 2022 | 07:55 AM
Gus's Avatar
Gus
Sorry but I have not had the opportunity to work on the Mercedes G5 Trans. I looked on the XK8 workshop manual to see if it had it listed but did not find it but I would assume it is near the XK8 procedure. I hope someone with that experience will chime in.
http://www.jagrepair.com/images/Auto...p%20Manual.pdf
Old Sep 16, 2022 | 10:41 AM
Phil m's Avatar
Incase this helps someone in the future.
To fix the problem all I had to do was change the Gear change control Solenoid situated to the NE of the Jgate.
£10 part.
https://www.autoreservejaguar.com/xj...interlock.html
XKRagTop
Aug 1, 2021 08:09 PM
tberry6686
Apr 27, 2015 02:50 PM
hibernianscribe
Jul 1, 2014 12:56 AM
craigh
Mar 11, 2011 09:11 PM
