Guess that sound! And help me, 00 XKR won't start.
Old Jan 30, 2016 | 06:05 PM
seawind's Avatar
Default Guess that sound! And help me, 00 XKR won't start.
https://*******/OKjx
For the past couple of months my vehicle has had a hard time starting when cold, sometimes you would have to turn the key twice but never any problems when running, today it finally won't start! It's not giving me any diagnostic codes just the p1111. I think it's my starter or fuel pump, could someone with more knowledge listen to the sound it makes when I try to start it and tell me what they think?
Thanks!
Old Jan 30, 2016 | 06:45 PM
Gus's Avatar
Gus
First have the battery tested.
Old Jan 31, 2016 | 10:46 AM
seawind's Avatar
I should have posted that was the first thing I did, it tested good! I have another Jaguar battery I could swap it with just to make sure.
Old Jan 31, 2016 | 10:53 AM
Gus's Avatar
Gus
Take the car to Autozone, Advanced Auto or Sears and have them do a load test on the battery. It is free!!
Old Jan 31, 2016 | 11:50 AM
seawind's Avatar
Sorry, to clarify that has already been done, Auto zone load tested it and it was good.
Old Jan 31, 2016 | 02:03 PM
Gus's Avatar
Gus
Two things to check the first is to swap your starter relay with another like relay and if the problem still exists check your ground at the battery and the one from the frame to the transmission bolt. It is on the right side of the trans just below the starter. The clicking leads me to believe that the starter solenoid is intermittent. Question does it do it when you try to start it in "N"?
Old Jan 31, 2016 | 02:16 PM
seawind's Avatar
I just tried to start it in neutral and now it won't crank at all in neutral or park. All the dash lights come on but nothing else happens.
Old Jan 31, 2016 | 03:09 PM
Gus's Avatar
Gus
Check your PM
Old Feb 1, 2016 | 12:33 PM
seawind's Avatar
Gus, responding to your pm now.
I did some basic troubleshooting with no luck.
1. Battery load tested good.
2. Swapped the starter relay, no change.
3. Checked fuses, all good:
fascia fusebox - driver's side
#6 5amps centre console switches, key transponder module, convertible top header console, rain sensing
engine compartment fusebox passenger side - within bulkhead extension
#3 25amps starter solenoid
engine compartment fusebox - left-hand side
#5 10amps starter relay, engine controle module
4. Tried another key, no change.
Fstbmw1
Feb 3, 2016 11:59 PM
Thermo
US Lower Atlantic
Feb 3, 2016 12:59 PM
Quicktruck
Feb 1, 2016 07:41 AM
Brian BigSkip Skipper
Jan 27, 2016 02:35 AM
nickxj6
Jan 26, 2016 06:23 PM
