Head preparation before gasket installation?
OK I'm working in my garage on my 98 xk8 and just watching the posts when I take a break. (I do that alot) I have both cam covers off waiting on tools and new tensioners and gaskets to show up...maybe tuesday. What's the best way to clean the aluminum surface of the head for new gaskets?
If the old cam cover seals were installed properly there shouldn't be a need for cleanup as these go on dry and they're a rubber material, like an O-Ring.
Sometimes they're incorrectly installed with gasket seal, or silicone or whatever is available in a tube, then I'd be scraping with a razor blade, BUT, you need to be careful as a single edge razor blade can actually gouge the aluminum.
If you're feeling the need to cleanup before installing, try a little isopropyl alcohol on a rag.
+1.
If the old covers were properly installed, there will be minimal cleanup. A small amount of solvent (carb cleaner, brake cleaner, alcohol) on a rag is all you should need. I would definitely avoid scraping the aluminum finished surface with a steel blade.
Thanks for the tips...the rubber gaskets came off cleanly but there was some residue around the outsides of the gaskets. I used some 50 cal gun cleaning patches soaked in wd-40. I left them on a few hours and everything cleaned up nice.
I was a machinist for 10 years of my working career and I can tell you I would never use anything metal to clean aluminum. One scratch and you have created a leak possibility.
I had a choice. I could spend $14K on an XK8 or I could spend $14K on a Barrett .50 cal. I figured I'd get more use out of the Jag, although I would LOVE to have a Barrett.
Once in a while I'll run into a DIY car where the owner really mucked up using sealants, but then I usually find other problems like overtightened cam cover bolts, etc. All contributors to more leaks.
aholbro1
Dec 29, 2024 06:46 PM
1964Daimler
Sep 9, 2015 11:20 AM
philwarner
Sep 5, 2015 10:05 AM
