head rest adjustment
Old Dec 9, 2008 | 12:46 PM
howardm's Avatar
Default head rest adjustment
How do you adjust the head rests on a 2005 xk8 coupe? The power adjustment is for up and down. There are slots in the headrest for titling forward and back. I just don't want to force anything.
Thanks!
Old Dec 9, 2008 | 01:39 PM
H20boy's Avatar
Default RE: head rest adjustment
Howard, I found this to be interesting also, but to 'tilt' the headrest, just use muscle. It is very stiff.
Old Dec 9, 2008 | 01:42 PM
howardm's Avatar
Thanks, yeah you know how it is, "don't force it" I'll give it a try.
H
Old Oct 18, 2011 | 01:08 PM
nfbandon's Avatar
Default Headrest
I just took delivery of my 2001 XK8. The only issue I have is with the headrests. As I understand it the middle button under the seat moves these. I have tried it. I get a noise, but don't see any movement of the headrest. Has anyone else had any issue here. I really don't need to move it up a lot...more need to move the headrest forward since I have to lean the seat back so much to fit into the cockpit at 6'4".
Grady
Old Oct 18, 2011 | 01:34 PM
Jochem00's Avatar
A good search on this forum will help you to find an answer to your question
Old Oct 18, 2011 | 03:20 PM
SeismicGuy's Avatar
Look in the FAQ section under headrest repairs. In short, the plastic sheathing that holds the cable that adjusts the headrest needs to be shortened. There is a bunch of stuff including a good video by Rev Sam that shows the entire process. It is a pretty straightforward DIY.
Doug
Old Oct 18, 2011 | 03:30 PM
Reverend Sam's Avatar
Doug
Yeah... it's straightforward once you figure out how to unclip the fabric at the bottom of the seat back. It took me three different attempts to figure out how it is snapped together.
Old Oct 18, 2011 | 04:38 PM
billm's Avatar
I think the initial question was how to adjust the Head Rests foreward and backward, not up and down. I am interested also, I would like to move my Head Rest foreward. It is fine as far as height wise...
Old Oct 18, 2011 | 05:48 PM
SeismicGuy's Avatar
Absolutely! If you track back through my earliest posts when I discovered I had the headrest problem on the driver's seat, you will see that most of my questions had to do with that first step of separating the fabric. I had tried the repair two or three times and gave up each time since I couldn't figure it out. Finally I tried one more time and accidentally stumbled on the method. The design is actually pretty brilliant and for quite a while I had thought that the fabric was physically sewn together. It is difficult to explain in words how to disconnect and then reconnect these pieces.
Doug
Old Oct 18, 2011 | 10:15 PM
Doug
One piece is shaped like a J. The other piece is straight. The piece that is straight clips into the J, but you have to fold it over first. But you don't fold the plastic piece, you fold where the fabric...
Nevermind. You're right. It is difficult to explain in words.
Old Oct 19, 2011 | 07:15 AM
dennisw's Avatar
this is my next job thanks to sam
aholbro1
Dec 29, 2024 06:46 PM
Razor
Aug 28, 2019 08:34 PM
jaguarguy13
XJ40 ( XJ81 )
Nov 8, 2015 08:16 AM
tampamark
Sep 14, 2015 09:12 PM
