hose clamps
Old Feb 24, 2015 | 01:41 PM
magnum454's Avatar
Smile hose clamps
Hi guys, I've ordered a new expansion tank for my 2000XK8 and my question is how tough are the oem hose clamps to grt off?
Old Feb 24, 2015 | 02:33 PM
brgjag's Avatar
you need the correct tool for it but can be done with channel locks or the like, either way the clamp can be hard to get too.
Gus's Avatar
Gus
You can reuse them but I elect to replace them with the good old screw type clamps as I go along.
Old Feb 26, 2015 | 02:40 PM
magnum454's Avatar
Gus tnx for reply. I'm not trying to re-use them, just how to get them off
Old Feb 26, 2015 | 02:46 PM
Gus's Avatar
Gus
Not like the one I have but will work
Link Sears.com
This is the one I have
link Sears.com
Old Feb 26, 2015 | 05:35 PM
test point's Avatar
I was able to use a pair of slip joint pliers to remove/replace the spring clamp at the bottom of the reservoir.
If you are asking about the small clips used between the thermostat housing and the reservoir they are easily removed by squeezing slightly with slip joint pliers and using a small screwdriver to release the clip holding the two sides together.
The clamp tool Gus linked to is really required for the lower hose at the radiator end if you want to reuse the spring clamp. I gave up on that location without the tool and used a screw clamp even though it would appear to be a good idea to use the spring clamps on hose-to-plastic connections.
The extended spring clamp tool appears to be the same across the internet available from $17 to $60.
http://www.ebay.com/itm/24-Long-Hose...487367&vxp=mtr
Old Feb 26, 2015 | 05:43 PM
brgjag's Avatar
what are the sizes of the orig clamps for the radiator hoses? where could I find them?
Old Feb 27, 2015 | 04:57 AM
magnum454's Avatar
thank you. it is the one between the t-stat and the res. tank.
Old Feb 28, 2015 | 12:50 PM
Pristine97XK8Convertible's Avatar
Just use a narrow-nosed pair of pliers and push the two halves of the hose-clamp away from each other orthogonally and they'll release; and of course these hose clamps can be reused by squeezing their open-ends together with a flat-nosed pair of pliers...
mikiep
Dec 20, 2019 07:37 PM
10 XF Premium
Oct 2, 2015 09:22 PM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Lubrication
Oct 1, 2015 03:56 AM
