how to remove headrest?
Old Sep 23, 2012 | 08:14 PM
stevepaa's Avatar
Default how to remove headrest?
I need to do the headrest fix but I first need to learn how to physically pull the headrest out of the seat. Someone did it before and put the plastic surround piece in upside down!?
So how do you yank the headrest out?
see update below
Old Sep 24, 2012 | 03:46 AM
dennisw's Avatar
Dont!!
if they are motor driven there is a cable that pushes them up and down..they are fixed
Old Sep 24, 2012 | 06:23 AM
Jag13cat's Avatar
Default Headrest Repair
As dennisw states - don't pull on the headrest
The headrest is motor driven by a cable extending from the headrest to a motor to the lower back support of the seat.
At the top of this section go to the "How to Videos". Rev Sam has a two part video detailing the repair to the headrest.
Old Sep 24, 2012 | 12:59 PM
stevepaa's Avatar
okay, but how do you remove the headrests? There must be a way becasue the factory had to assemble it.
Do I release the cable and then pull the headrest up?
Old Sep 24, 2012 | 01:09 PM
Jag#4's Avatar
The headrest fix does not require removal of the headrest itself. All repair is done inside the seatback. See Sam's two-part video on this in the stickies for process.
Old Sep 24, 2012 | 05:04 PM
stevepaa's Avatar
we are not communicating.
I know about the head rest fix.
My problem is I need to replace the plastic piece between the headrest and the seat.
Old Sep 25, 2012 | 09:55 AM
H20boy's Avatar
I am confident you can totally remove the headrest. Once the cable is removed from the motor, there is also a plastic 'T' part that both pedestals of the headrest connect to, and it is connected to the said cable at the center. You will see it once you dismantle and pull up the seat cover almost all of the way up.
Old Sep 26, 2012 | 11:04 AM
dennisw's Avatar
a crow bar should do it
Old Dec 23, 2012 | 01:02 PM
stevepaa's Avatar
Just pull up and they release from the actuating mechanism. It is a ball and socket fit.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
mrsimpson
Sep 15, 2015 01:10 PM
SeanU
Sep 14, 2015 04:31 PM
doctordeuce
Sep 12, 2015 08:30 AM
