How to remove this hose clamp?
Old Apr 7, 2017 | 09:06 AM
Anthony8858's Avatar
Default How to remove this hose clamp?
Getting past my basic tools, and I'm stumped getting this hose clamp off.
I'm replacing the Reservoir bleed hose today.
Is there anything I need to know besides a simple direct approach?
Any surprises I should be concerned about?
Old Apr 7, 2017 | 09:09 AM
bladerunner919's Avatar
You'll need to either bend it open, or snip the metal along the bit that is crimped (the right-hand bit in the image). They're not re-usable, so make sure you have replacement jubilee clips to hand.
Old Apr 7, 2017 | 09:23 AM
WhiteXKR's Avatar
Actually they can be reused if removed carefully. Squeeze across the outermost protrusions with a pair of pliers, then while continuing to squeeze the pliers use a small screwdriver to gently lift the latch in the center.
Squeeze again till it clicks to reinstall.
Old Apr 7, 2017 | 09:28 AM
Curious.... what exactly does this hose do?
Can't find anything online
Old Apr 7, 2017 | 09:54 AM
MRomanik's Avatar
Veteran: Air Force
Air bleed
Old Apr 7, 2017 | 11:02 AM
Chuck Schexnayder's Avatar
The clamps are simple AND re-useable.
Looking at the picture, there are two raised rounded areas. One on the right, one on the left. In the middle is a smaller rounded area.
Take a sharp small pointed punch, put the point under the left rounded area and let the punch rest on the center one. Apply downward pressure on handle of punch and "snap", the clamp snaps open. (Don't have one in front of me, so you may have to experiment on what way to use the punch--right or left--but that's the idea) To re-ruse, put the clamp on the new hose, put the hose on the nipple, then using the two outer rounded areas, squeeze them together with a standard pair of pliers until you hear it "snap" together. Have used them over many times. Great little clamps.
Old Apr 7, 2017 | 11:05 AM
They aren't designed to be reusable, even if they can be, so why bother? It's not as though a jubilee clip is an expensive bit of equipment.
Old Apr 7, 2017 | 01:05 PM
Ungn's Avatar
It surprised the heck out of me when I squeezed that clamp together and it went "click".
I remember saying "cool".
Old Apr 7, 2017 | 01:09 PM
RJ237's Avatar
They definitely are designed for reuse, and with a little practice are very easy to open and close.
Old Apr 7, 2017 | 03:46 PM
toaster's Avatar
+1, all absolute right
Old Apr 7, 2017 | 03:52 PM
White Bear's Avatar
WhiteXKR is perfectly correct, and yes if done carefully it is reusable.
Regards,
Old Apr 8, 2017 | 06:49 AM
Jon89's Avatar
They are indeed reusable, but I do not like them. Whenever I have to remove one to repair the vehicle, I replace it with a standard worm-drive clamp....
Old Apr 8, 2017 | 08:32 AM
motorcarman's Avatar
A POCKET SCREWDRIVER!!!!!!!!!!!!!!!!!!!!!
bob
Old Apr 8, 2017 | 03:09 PM
tsuppari's Avatar
That is Click-R clamp. There is special pliers for them:
http://76.my/Malaysia/clic-r-collar-...onngu77@17.jpg
Old Mar 30, 2023 | 01:52 PM
Jag&Furious's Avatar
I broke the bleed hose 2 days ago while changing the supercharger oil and was wondering how to open that clip. That really helped thanks you ;-)
Old Mar 30, 2023 | 02:30 PM
zray's Avatar
Aside from being reusable the stock clamps are a constant pressure type of clamp, which is superior to the basic worm-drive hose clamp.
I always reuse mine. No leaks so far.
Z
Old Apr 1, 2023 | 05:22 AM
Pistnbroke's Avatar
You asked whats the pipe for ...remember there is an inlet at the bottom of the tank and this is bleed back into the main system. If there is any air it will be in the expansion tank.
Top up right to the top to keep the overflow system working.
Old Apr 1, 2023 | 06:31 AM
I knew I'd done a post on opening/closing this type of Norma Clip but didn't think it was as long ago as 2012!
https://www.jaguarforums.com/forum/x...-pliers-77985/ (see post #7)
There is a the inevitable 'special tool' available but I've always found pliers sufficient once you know where to press.
Old Apr 1, 2023 | 07:41 AM
Jon89's Avatar
Graham,
2012 was just the blink of an eye ago. Interesting how the years go by so much faster as we age....
AlexJag
Jul 3, 2024 12:34 PM
TimCanJag
Aug 6, 2020 06:32 PM
randyb
Sep 1, 2016 02:08 PM
giandanielxk8
Feb 15, 2016 07:20 AM
cdaubs
E type ( XK-E )
Sep 1, 2012 02:15 PM
