Hydraulic fluid type for roof pump?
Old Nov 20, 2020 | 08:20 AM
Pristine97XK8Convertible's Avatar
Default Hydraulic fluid type for roof pump?
Gentlemen:
The fluid level in the reservoir is below the minimum level. Can someone tell me what type of hydraulic fluid should I use to top it up? TIA.
Old Nov 20, 2020 | 08:32 AM
Jon89's Avatar
The current standard is Pentosin CHF11S which is green in color. What color is the fluid currently in your system?
Old Nov 20, 2020 | 10:17 AM
rothwell's Avatar
I might be captain obvious here. If the reservoir is low there is a reason for the loss of fluid. These systems don't naturally consume/lose fluid. Start looking for a leak somewhere at all the known failure points.
Old Nov 20, 2020 | 11:19 AM
Thanks for the info. Let me check the color and come back to you.
Old Nov 20, 2020 | 11:23 AM
You've got a very good point there, tracing where the fluid had gone. Thanks for reminding me to look for the leaking place(s).
I remember topping it up at least 3 years ago, but forgot what fluid I'd used.
Old Nov 20, 2020 | 01:22 PM
motorcarman's Avatar
I hope the UNIVIS was already flushed from your system in the past when the TSB (501-33am) was issued to flush and replace that fluid.
The 1997 to 1999 conv used UNIVIS and the 2000MY onward used Pentosin CHF 11S
Old Nov 23, 2020 | 09:14 AM
@motorcarman:
This is the first time I've heard about TSB (501-33am). Do you know what color is UNIVIS? I do not know if the previous owner(s) has flushed the UNIVIS.
The last time I topped it up at least 3 years ago was with Pentosin CHF 11S. The fluid in the reservoir now is green in color like Pentosin, This is the current state.
The roof will raise/lower with about a 20 second delay due to the low fluid level.
BTW, I got myself a new can of fluid and the name is now called FUCHS Titan CHF 11S. If I proceed with the flush, would one Litre of fluid be enough?
Old Nov 23, 2020 | 09:25 AM
UNIVIS is YELLOW.
The (Central Hydraulic Fluid) CHF11S is GREEN
Old Nov 23, 2020 | 11:04 AM
UNIVIS is YELLOW.
Since the color of my current fluid is GREEN, I presume a previous owner has flushed the system with Pentosin.
I'd simply go ahead with topping it up with CHF 11S.
Wish me the best of luck...
Mogmichael
Nov 9, 2025 12:11 PM
jeffp634
Jul 11, 2017 09:24 PM
Anthony8858
Dec 27, 2016 07:14 PM
Ship
Dec 30, 2015 08:21 PM
Powdercoater
Feb 24, 2013 08:33 PM
