'Idle' battery drain
Old Feb 1, 2012 | 11:00 AM
steveinfrance's Avatar
Default 'Idle' battery drain
Does anyone know what the actual battery drain current of XKR's is when they're switched off?
I could disconnect the battery and measure it, I know, but there's 6" of frozen snow against the garage door at the moment and tomorrow will be -11°C so my motivation isn't too good!
Old Feb 1, 2012 | 11:33 AM
WhiteXKR's Avatar
See attached.
File Type: pdf
Old Feb 1, 2012 | 11:45 AM
Originally Posted by WhiteXKR
See attached.
Perfect. I've got a 50mA constant current source limited to 13.5 V which looks as if it will keep things topped up.
Thanks again.
Old Feb 1, 2012 | 01:19 PM
avt007's Avatar
Buy a battery maintainer, CTEK makes a nice one.
Old Feb 1, 2012 | 03:26 PM
jamjax's Avatar
Thanks Steve and Whitey.
I was going to ask the same question after I saw someone on the XK forum bring it up for post 2006 cars.
If I read this correctly the '96-'06 XK8's does not benefit from the keyfob lock up to stop battery drain.
Correct or not?
Course until two days ago I was still driving it......when the EU wide blizzard hit.
cheers from the Ice Cave,
jj
Old Feb 1, 2012 | 04:21 PM
WhiteXKR's Avatar
Correct or not?
jj
30mA is pretty low standby drain, about 0.9% of the battery charge per day. I believe it goes into full sleep automatically after 28 days (key fob no longer works until the car is restarted), where the drain close to zero.
Old Feb 1, 2012 | 04:57 PM
jamjax's Avatar
Thanks Whitey.
I am not going to worry about it then.
cheers,
jj
aholbro1
Dec 29, 2024 06:46 PM
Charlene n John
Sep 14, 2015 10:08 AM
vincent661983
Sep 10, 2015 05:52 PM
obwoodie
Sep 3, 2015 07:45 PM
Bowman
Sep 3, 2015 03:17 PM
