INSTALLED NEW BATTERY
Old Jan 1, 2009 | 04:35 PM
lcyoung's Avatar
Default INSTALLED NEW BATTERY
HEY I HAVE A 2002 JAGUAR XKR. IN MY BATTERY WENT DEAD. SO I BOUGHT ANOTHER ONE IN INSTALLED IT. IN WHEN I ROLL MY WINDOWS UP. IN GET OUT THE CAR. IN CLOSE THE DOOR THE DOOR WONT CLOSE. SO I OPEN IT BACK UP IN THE WINDOW COME DOWN. IN THE THE DOOR WILL CLOSE. SO I LOCK THE DOOR IN THE ALARM GOES OFF. IN THE DOME LIGHT STAYS ON. I DO NOT KNOW IF I HAVE TO RESEST ANYTHING AFTER REPLACING BATTERY. BUT I NEED HELP. BECAUSE I HAVE TO UNHOOK THE BATTERY EVERYTIME..
Old Jan 1, 2009 | 06:07 PM
test point's Avatar
Default RE: INSTALLED NEW BATTERY
I would suggest that you disconnect the battery and charge it in that condition. Low battery voltage is famous for causing all sorts of strange issues. Just because it is a new battery does not mean that it is fully charged.
Are you sure you do not have a charging system issue that caused the previous battery to fail? Have you driven the car enough after replacement to fully charge the battery?
Old Jan 1, 2009 | 07:29 PM
lcyoung's Avatar
i work at the auto part place. i made sure the battery was fully charged. so it should b charged to the fulliest.now i havent been driving the vehicle like that. n i check the old battery and the previous owner put a reconditioned battery in it. so most likely that one wasnt no good anyway
Old Jan 2, 2009 | 12:32 PM
H20boy's Avatar
I had this problem when i had some audio work done, and they disconnected power for quite a while. To fix the bugs, do a 'soft' reset, by disconnecting the negative terminal for about 5 minutes. Reconnect, reprogram your windows (if a convertible), and alarm and everything else should work.
Old Jan 2, 2009 | 03:43 PM
hlgeorge's Avatar
I would do a full reboot. Disconnect the positive battery cable for a few minutes. Then touch the positive connector to the negative terminal for a quick second. Reconnect the positive battery cable to the battery. You will have to reset the window 'auto drop' function as described in your owners manual, be it a convertible or a coupe. You will also have to reset your radio presets and the transmission will have to re-learn your driving profile. Let us know if it works.
Old Jan 5, 2009 | 01:49 PM
lcyoung's Avatar
tHANKS that fixed d problem
Old Jan 11, 2009 | 10:28 AM
H20boy's Avatar
Hey lew, I hate re-educating my tranny. lol
Old Jan 12, 2009 | 03:30 PM
hlgeorge's Avatar
If you got a tranny, you need to tell him/her to finish school!!! LOL [sm=interesting.gif][sm=imsorry.gif]
Dagny
Jun 11, 2024 01:06 PM
Ozmag
Oct 1, 2015 09:34 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
speacock
Sep 10, 2015 12:14 AM
mcdutch
Sep 4, 2015 03:38 AM
