installing rear quarter window regulator
Old Sep 22, 2013 | 05:46 PM
OhioXK's Avatar
Default installing rear quarter window regulator
The JTIS guide isn't very helpful regarding this:
Guiding link lead through water shedder (later type), lower motor/regulator assembly through upper aperture and locate adjusters in body apertures
I had to disassemble the old regulator in order to remove it, and I haven't been able to fit the new regulator into the opening. It's jamming up on the convertible top bracket; I read a .pdf which claimed that it should clear that bracket if the bracket was pried out ~0.5", however despite doing so, I still can't get it to fit.
Any suggestions, other than removing the convertible top?
Old Sep 22, 2013 | 05:56 PM
Gus's Avatar
Gus
Is this the PDF you were reading?
Link http://www.jagrepair.com/images/Auto...lacement-2.pdf
Old Sep 22, 2013 | 06:30 PM
OhioXK's Avatar
yes I followed the .pdf exactly as stated, however I'm unable to pry the bracket out far enough to provide the clearance required.
Old Sep 22, 2013 | 08:38 PM
Gus's Avatar
Gus
I wish I could offer assistance with it but I have not done this project myself. Have you done a search on this forum to see what others might have done?
Old Sep 22, 2013 | 09:14 PM
I remember this was a pain to install but can't remember exactly how I actually got this in place
Old Sep 22, 2013 | 10:13 PM
Gus's Avatar
Gus
I have often walked away frustrated to turn and see it another way.
Old Sep 23, 2013 | 12:49 AM
jodypress's Avatar
I've just replaced the regulator myself a few weeks ago. It's definitely a two man job. Also make sure the window is half way up when trying to put in the regulator.
Old Sep 23, 2013 | 02:25 PM
OhioXK's Avatar
Other than one fellow who mentioned using a hammer I found no information regarding this. It appears that those who replaced the regulator without removing the top all had 2002 or earlier models. Mine is a 2003; perhaps something was changed that year which requires removing the top.
Old Sep 23, 2013 | 04:04 PM
Gus's Avatar
Gus
If I were closer I would come over and help.
Old Sep 27, 2013 | 06:24 PM
OhioXK's Avatar
After screwing around with this for a few weeks I called North Coast Exotics in Cleveland and explained the situation to the owner.
He said they normally charge $200 to replace the regulator. Wasn't even worth my time researching the problem on the internet, let alone my time spent fussing with the repair.
Unfortunately, after he saw the car, he said there would be additional labor involved due to my having disassembled much more than he would have, so it did cost a bit more. When I asked him how he fit the regulator into the cavity, he said "you pull the body away." I've no idea how one would go about doing that.
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
