Interior rear view mirror type?
Old Mar 30, 2016 | 05:15 PM
bcucharternet's Avatar
Default Interior rear view mirror type?
Can you tell from the VIN number which interior rear view mirror you need to get to replace the existing fogged unit in my car. I understand there are several different types having different number of wires. I would like to order one and remove mine when the new one arrives.
bcucharternet
Old Mar 30, 2016 | 08:58 PM
dennysjag's Avatar
Do you have "auto" settings on the widshield wiper stalk and the headlamp stalk? If so you will have rain sensing and headlamp sensing. The auto dim is present on all
Old Mar 31, 2016 | 07:12 AM
Yes I do have auto on the wipers and the headlights. Ho many wires will the correct mirror have?
bcucharternet
Old Mar 31, 2016 | 07:31 AM
Rick L's Avatar
bcucharternet. You should search on rearview mirror. There is someone on the forum that rebuilds your old mirror. I believe it would be easier and less expensive to go that route
Old Mar 31, 2016 | 07:33 AM
Rick L's Avatar
Here is the link https://www.jaguarforums.com/forum/x...acement-17719/ They are called Sybesma Electronics.
Old Mar 31, 2016 | 08:39 AM
RDMinor's Avatar
bcucharternet
I give a +1 to the suggestion to use Sybesmas to repair your existing rearview as trying to get a used one from eBay or elsewhere is not only problematic but also way more expensive if it's a working unit.
You say your is fogged but it's probably got a problem with the electro-luminescent fluid that's contained in the mirror that causes it to go dark when someone's high beams hit it from behind.
In any case Sybesmas can fix it and make it like new for about $100 plus shipping. I had them do two for me including one that has not only the auto-dim feature but the rain sensor built-in as well and they both came back looking like brand new units.
Sybesma's Electronics
Old Mar 31, 2016 | 07:00 PM
dennysjag's Avatar
I cant remember the number of wires. I think it was 5. It is easy enough to remove the overhead console and the bracket to expose the connectors. Then you can count the wires if you want. I had luck finding a good used one on this forum. I don't think I would have used any ebay sellers or junk yards unless you can see and touch the item.
Old Apr 1, 2016 | 07:49 AM
RDMinor's Avatar
Default How many wires???
bcucharternet
If you indeed have the rain sensing automatic wipers in your car there should be 8 wires with an 8 wire connector. You can expect to pay $300 or more for a used working one while you can get it professionally repaired for right at $100.00
PatrickO
Mar 9, 2017 07:17 AM
littlelic69
Nov 17, 2016 09:59 PM
Panhard
Mar 7, 2016 06:03 PM
ukdeluded
Mar 5, 2016 11:08 AM
kiwijohn
General Tech Help
Mar 3, 2016 12:54 PM
