interior squeak in my xk8
Old Apr 28, 2023 | 08:40 PM
bjb1946's Avatar
Default interior squeak in my xk8
I've read and looked at just about every utube video on XK8 interior squeaks . Even tho the squeak seems to be coming from the front of the interior, I've had the front shocks and rear shocks replaced . I've taken the steering wheel off to grease the 8 contacts like the jaguar update suggest. i'v removed and used silicon grease to coat the interior of the console front & sides. I' replaced the seat latch rubbers where the seat snaps back to latch the seat when in the normal position. I've even silicone the edges of the two doors. The squeak is like chalk screeching against a blackboard . it squeaks only when hitting a bump, doesn't have to be a hard one. None of the squeaks are coming from the door interior. i've also as one video suggested tightened the screws for the small speakers in the right and left side of the top of the dash. Hoping for helpful suggestions or even a jaguar Squeak specialist that can address this. Thanks to all who respond.
Old Apr 29, 2023 | 06:12 AM
welcome to the forum - as this is your first post, when you have a minute stop by the New Member section and post an intro and in return, you will receive a warm welcome and useful tips/pointers on navigating the forum New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
The dreaded squeak - look at your front upper shock mounts and the position of the nut on the top of the shock. When they replaced the front shocks, did they replace the upper mount and how long ago were they replaced? If upper mount was replaced, did they use OEM or aftermarket parts? Does it show signs of crumbling? Is that nut off-center? Pics posted below. Are the nuts holding the shock assembly tight and what about the brace that runs from the shock to the cowl? If there is anything loose with the upper mounts or brace, certain movements (going over bumps) will cause metal to metal rubbing of the brace to the frame which is an annoying noise. I have replaced my upper mounts 3 times in 11 years of ownership
Old Apr 29, 2023 | 08:09 AM
motorcarman's Avatar
Info from Jaguar.
File Type: pdf
File Type: pdf
Old Apr 29, 2023 | 10:48 AM
drmike's Avatar
I have a squeak from where the seat belt seems to rub against something if the seat is too low. Maybe fiddle about with the seat height? You don't seem certain where it's coming from.
Old Apr 29, 2023 | 10:49 AM
JimmyL's Avatar
When my front shock mounts were falling apart, it sounded like a bird was chirping behind the dash. I tried all kinds of things until I replaced the mounts.
Old Apr 29, 2023 | 12:08 PM
Maybe out of VIN range but.................
Old Apr 29, 2023 | 02:11 PM
drmike's Avatar
That's well worth a shot although out of VIN range. I shall look.
Old Apr 29, 2023 | 02:36 PM
Terrific's Avatar
Check the windshield stainless for rubbing on glass, small pieces of rubber tape solved my problem. Drove the car on 11hundred mile trip when first got the car almost drove us crazy. Actually think that is why the previous owner sold.
Old May 2, 2023 | 12:06 PM
Flash-1973's Avatar
Default My squeak resolve.
Hi, Till 3 mths ago I had a squeak coming from what I thought was where the windshield meets the dashboard. I was diving in a parking garage with windows open and heard it outside my 2001 xk8. Turns out it was the hood/bonnet latch. Lubricated and tada. It was making me nuts, no matter how loud the music was.
slugger
May 22, 2023 02:24 PM
Smitty99XKR
Jan 9, 2022 01:46 AM
ukdeluded
Apr 7, 2019 05:47 AM
Ophitoxaemia
Oct 31, 2018 12:24 PM
magredvet
Oct 15, 2012 08:13 PM
