I've officially joined the club!
Old Feb 16, 2012 | 04:06 PM
Italianguy63's Avatar
Default I've officially joined the club!
Well, after over a month... I picked up my 2004 XK8 today. It has been renamed from "Missing in Action" to "Abbey." Either for Abbey Road, or Abbey-Normal... you can choose. The dealer could not figure out the Driver Airbag light.. and I think I already have. I push the seat all the way back (I'm a big guy), and the light went out. So, thinking a bad connection on the seat harness probably. Has a few other issues I have to figure out. 1. Window on Driver side (Left in US) goes down when you lift the handle, but does not go up when you close the door. 2. Dealer/Wholesaler "misplaced" all the keys and fobs except one set. It seems the key fits everything except the Driver door? Any ideas about this???? Any help on my minor problems is appreciated! Mark
Old Feb 16, 2012 | 04:20 PM
jamjax's Avatar
Hey IG;
Congrats on your new baby. Great color!
Don't forget the mudflaps.
There is a way to reset the window stops in the manual.
If you don't have that there are PDF versions in the FAQ sticky threads when this section of the forum opens.
No idea why your key doesn't fit the drivers door, unless that lock was replaced or damaged.
enjoy,
jj
Old Feb 16, 2012 | 05:15 PM
Looks great!
All the waiting will be forgotten now.
It does sound like something has happened to the drivers door lock, that would be annoying.
Old Feb 16, 2012 | 05:48 PM
Hey-- already making progress. I got the lock unjambed... it is working again. And, it seems like the "auto" switch to make the window go back up is inoperative. The one in the armrest works, but it does not automatically go back up, and the key does not raise that 1 window (but the other 3 go up). I have determined the mechanic took that door apart chasing the airbag light -- and probably skanked something up. I'm just glad to be making progress already. Not many things wrong that need attention. The important thing is it drives and handles stellar!! MC
Old Feb 16, 2012 | 05:58 PM
Paul Pavlik's Avatar
"Window on Driver side (Left in US) goes down when you lift the handle, but does not go up when you close the door".
While sitting in the car with the door closed and the Engine Running:
Raise the window and continue to hold the button down for 5 more seconds.
Repeat for Window Down.
Repeat for the other Door.
Old Feb 16, 2012 | 06:16 PM
Nice ride Mark.....congrats ....
Old Feb 16, 2012 | 06:28 PM
K.Westra's Avatar
Sharp ride! Just a correction on Paul's post: the engine doesn't need to be running to reset the windows.
Old Feb 16, 2012 | 06:52 PM
Paul-- you are the man! I went out and it actually seemed to be working, but I followed the proceedure anyway. Seems there is one more problem licked!! Thanks!
Found a few bulbs burnt out in the gauges, but saw an article on that a few days ago.. Life is good.
Thank you gentlemen!
MC
Old Feb 16, 2012 | 07:17 PM
Originally Posted by Italianguy63
...............Dealer/Wholesaler "misplaced" all the keys and fobs except one set................
You finally got it home and look to be making rapid progress on the faults.
After all the time they spent on the airbag problem it sounds as if the fix is going to be a lot easier than you thought.
The missing keys and fobs isn't such good news. You can usually pick up fobs on eBay. Make sure the number on the back is the same as the one you have and don't get European ones because they're a different frequency. Keys aren't so easy. They have to be programmed by the dealer.
Old Feb 16, 2012 | 09:37 PM
True, if the reset doesn't "Take" with the Alternator not running, a Battery replacement is indicated.
Old Feb 17, 2012 | 03:12 AM
Yes. Great progress already. I have set some time aside this weekend that I can dig in and try to chase the intermittent SRS light. I will take the connections apart and clean them. I will read the article on the dash bulbs again, and still thinking about those mudflaps . I actually found a locksmith in Orlando that can cut and program the Jag keys.. And, I had already been looking on eBay for another fob. Thank you all for the technical help and support. You are a great bunch of guys and a great site! MC
Old Feb 17, 2012 | 03:30 AM
jamjax's Avatar
IG;
Originally Posted by XKRacer
I have removed dozens of mud flaps from XK8s and Rs, there is no difference...... If anybody asks me what XK to buy, I always say try to buy one that has mud flaps, your sills wont rot away in years to come!
I like them
Racer is the only tech guy I know that does rusted door sill and fender well replacements and protection.
I am getting a set of mudflaps as we speak.
You should consider them if you drive or live near the coast since sea spray is just as corrosive as snow salt up north.
cheers,
jj
Old Feb 17, 2012 | 03:47 AM
I am a fan of mudflaps-- In Florida, it rains all the time, and the wings always look like heck. The flaps keep the spatter down. From the pictures I have seen, the factory flaps do not seem obtrusive. I will probably get a set, put them on, and see how they look. If I don't like them, I can take them back off... MC
Old Feb 17, 2012 | 04:01 AM
Cadillac's Avatar
Congrats, nice color
wichita
E type ( XK-E )
Apr 16, 2016 04:00 AM
Clare Jennings
Oct 4, 2015 05:43 PM
wonderwire
Oct 4, 2015 05:41 PM
Vector
US Lower Atlantic
Sep 28, 2015 11:08 AM
