Jagrepair.com
Old May 20, 2023 | 05:35 AM
Rishi's Avatar
Default Jagrepair.com
I am trying to diagnose my roof problems and I see some great pictures on Google (cached) at Jagrepair.com but when I navigate there it says the site can’t be found. Is it still available?
Old May 20, 2023 | 05:41 AM
michaelh's Avatar
Hi Rishi,
I think Gus moved the site some time back, but it is alive, well, and a great source of information.
Post the URL you're trying and I'll see if I can help.
Old May 20, 2023 | 06:09 AM
Rishi's Avatar
JagRepair.com - Jaguar Repair Information Resource
Old May 20, 2023 | 06:33 AM
Rishi's Avatar
Thanks. For some reason its blocked from The Netherlands. Switched my VPN to US and now I have access.
Old May 21, 2023 | 08:47 AM
Markmbaha1's Avatar
Default Pages loading blank in jaguarrepair
I'm trying to find information on an engine hesitation and momentary rpm drop when mildly acceleratimg in my 2004 xkr cruising about 40is mph, press accelerater but not hard enough to make gear downshift. The engine will rev, then drop back in rpm' then start to rev up. Very abnormal for any car. If you press on gas to accelerate it should smoothly keep accelerating. I've replaced maf, filter is almost new, air filter is new, air tube is secure on both ends, no cracks found in air tube...when monitoring fuel pressure, I recorded screen view of life fuel pressure and maf. Fuel pressure does fluxuate under acceleration and deceleration. It seems the medium reading is 55. It will drop to 51, 52 and 1 moment it read 48 but I can't duplicate that. It will rise slightly as well. I'm told it should stay at 55 fuel pressure. I thought I found a page on jagrepair.com to address it, but page loaded blank.
How can i best research this problem? TY Mark
Old May 21, 2023 | 09:48 AM
Rishi's Avatar
If you have a VPN connect using the VPN and try again.
Old Jan 3, 2024 | 01:30 PM
Dutch_Razor's Avatar
First of all, many thanks to Gus for hosting jagrepair.com!
Also I cannot access the website from the Netherlands without using a VPN, might it be possible to unblock us Dutch people?
E.g. http://jagrepair.com/BeltTensioner.htm doens't load normally but it does on VPN or Tor.
Old Jan 4, 2024 | 08:37 AM
You could contact @Gus and ask if he could help.
Or he may swing by soon.
Old Jan 16, 2024 | 04:29 PM
Gus's Avatar
Gus
What is it that you need?
E.g. JagRepair.com - Jaguar Repair Information Resource doens't load normally but it does on VPN or Tor.
Ron1
Nov 11, 2021 10:28 AM
YEG
F-Pace (X761) / C-X17
Jul 19, 2016 03:03 PM
malc4d
Jan 19, 2015 12:06 PM
gkazimir
Apr 11, 2013 11:14 PM
Simprof
Jul 5, 2011 03:31 PM
