Key Fobs not working
Old Aug 12, 2013 | 06:28 AM
Conan's Avatar
Question Key Fobs not working
Originally Posted by Maureensxtype
Think I can help with key fob Re-programming instructions. Need to know which car you have to help. Instructions that I have are for UK cars but hopefully will work with cars elsewhere. Believe main difference is,
433MHz (for UK) 315Mhz (for US/Canada) I have instructions for most models for example,
X TYPE. XK. XJ6. Think I could find them for S Type as well.
Hoping you can help - I have just bought a 1999 XK8 (UK) and neither of the keyfobs work at all. Have replaced the batteries and found some instructions (suspect US) for reprogramming them but they still don't work. Would appreciate copy of UK istructions if you still have them.
Having to use key to lock doors and have to get key in ignition quickly when I open or alarm goes off. Trying to avoid taking to dealer if I can help it.
Also can anyone recommend a good UK workshop manual fo the car? Checked Amazon but the Haynes manual looked more like an appreciation book rather than the usual blow by blow workshop manual
Old Aug 12, 2013 | 07:15 AM
Conan,
I've moved your question from the X-Type section to the XK8/XKR section. Keyfobs are different on your XK8.
Old Aug 12, 2013 | 07:25 AM
philhef's Avatar
Have the same issue.
I ordered the fobs off ebay but didnt make sure the numbers and codes were exact matches as my original one. There are several different fobs that look identical except for the numbers. All the numbers on the back of fob MUST be a match. I bet yours may be different.
Once I got the correct part numbered fob, it paired up perfectly.
Old Aug 12, 2013 | 07:31 AM
WhiteXKR's Avatar
The official workshop manual is on CD, and you can down load it free. It is called JTIS and the details are in the beginning of this post: https://www.jaguarforums.com/forum/x...ts-data-29800/
Old Aug 12, 2013 | 09:26 AM
Originally Posted by Conan
.............. I have just bought a 1999 XK8 (UK) and neither of the keyfobs work at all. Have replaced the batteries and found some instructions (suspect US) for reprogramming them but they still don't work............
Try reprogramming both fobs before assuming they are either incompatible or faulty.
1. Insert ignition key into the ignition switch barrel, but do not turn it.
2. Hold the turn signal switch stalk in the "flash to pass" position and turn the ignition on with the key (while holding the turn signal switch in "flash to pass").
3. Then repeatedly flash the lights with the turn signal stalk until a confirmation chirp is heard (usually five or six flashes).
4. After hearing the chirp, depress the button on the remote transmitter being programmed. If the remote was accepted, there will be another confirmation chirp.
5. this button press procedure has to be repeated 5 times - if you have 2 remotes, programme the 2nd remote 4 times, to make a total of 5 programming procedures.
6. Turn off the ignition and test the remote(s).
Old Aug 12, 2013 | 10:33 AM
aardvark64's Avatar
When I did this for my '99 XKR, I followed the steps in the previous post. However, the module didn't chirp; instead, a light flashed a few times on the J-gate surround.
Another oddity is that some folks (me included) had to have the driver's door open when reprogramming the key fobs. This may (or may not) affect you...
Good luck and good choice of car!
Best wishes, Colin
Old Aug 12, 2013 | 12:40 PM
Conan's Avatar
Will keep trying all the combinations, but so far nothing. Is that turn the ignition on ie engine running, or just to position 1 ir 11?
I found the valet switch on the dashboard and tried that instruction but unfortunately the valet button has a tendency to stick which makes pushing it 5 times in 5 seconds near impossible - but I shall percivere
Thanks for all the suggestions - keep them coming
Old Aug 12, 2013 | 12:52 PM
Step 2 is the with the Ignition ON (position II) and not with the engine running.
Old Nov 3, 2013 | 03:40 PM
Diamondrmp's Avatar
My remote stopped working so I did a search and came across this thread. It worked perfectly, my remote is working again. Thank you!!!
philwarner
Oct 4, 2024 01:37 PM
Sprayall
May 30, 2021 08:13 AM
XJsc-guy
Nov 23, 2015 01:56 PM
philwarner
Sep 5, 2015 10:05 AM
Sprayall
Sep 3, 2015 07:49 PM
