Keyfob battery(ies)
Old Jun 21, 2020 | 03:50 PM
radjag1's Avatar
Default Keyfob battery(ies)
Hi
What battery goes in a 98 XK8?
I have 2 remotes. One has 2 2016s in and works. The 2nd has one 2032 and is not working or battery dead.
One googled but not getting a straight answer.
Rob.
Old Jun 21, 2020 | 07:33 PM
avern1's Avatar
1 each 2032 can replace 2 each 2016's either will power the remote. Make sure the + is in the right direction.
Old Jun 21, 2020 | 09:13 PM
motorcarman's Avatar
ALL 20xx (20mm x 1.6mm, 2.5mm, 3.2mm) batteries are 3 VOLTS.
2016=20mm x 1.6mm-3 VOLTS
2025=20mm x 2.5mm-3 VOLTS
2032=20mm x 3.2mm-3 VOLTS
Stacking the batteries (series connection) will provide 6 Volts.
Make sure you install the correct battery(s) for the keyfob transmitter you have.
To >VIN A11050 should require TWO (2) CR2016 batteries. (JLM11905)
From VIN> A11051 should require ONE (1) CR2032 battery. (JLM20930)
I think the VIN and battery combos are correct?
Old Jun 22, 2020 | 02:35 PM
radjag1's Avatar
Hi
Don't want to sound like an idiot but this is my vin: SAJGX2246WC028772. Where is the "A" you are talking about?
Rob
Old Jun 22, 2020 | 03:45 PM
Jaguar VIN and production date info.
bob
File Type: pdf
Old Jun 22, 2020 | 05:56 PM
radjag1's Avatar
Again I don't want to be an idiot, but how did this Vin info you forwarded answer the fob question?
Old Jun 22, 2020 | 07:51 PM
michaelh's Avatar
The format of the last 6 characters in the VIN changed from 6 digits to 'A' + 5 digits after ....042775, essentially with the introduction of the 2000 MY.
Your VIN of .....028772 precedes the start of the A + 5 digits, hence the fob requires 2 x CR2016 cells as per motorcarman's list in post #3
Old Jun 23, 2020 | 05:19 PM
radjag1's Avatar
I replaced batteries, 2X 2016, and appears remote is dead. Now I need to get a replacement. This remote looks brand new with no wear. Ugh!!!
Old Jun 23, 2020 | 05:55 PM
michaelh's Avatar
May be dead, or maybe it's not recognised by the car.
Do you know a friendly radio ham or someone with a scanner covering 315MHz? It should be possible to determine if it's transmitting or not.
Guillaume Lemaire
Oct 24, 2020 03:27 PM
150FHC
Apr 8, 2020 06:11 AM
cobratom
Dec 11, 2017 10:54 AM
krswen
Sep 28, 2015 02:28 PM
jjf
Sep 16, 2012 10:56 PM
