Kick Plate removal for top hydraulic hose
Old Feb 11, 2015 | 08:48 PM
BlkCat's Avatar
Default Kick Plate removal for top hydraulic hose
Is it possible to remove the kick plate by the driver's door without destroying it when changing the top hydraulic lines?
Thank you
Jack
Old Feb 12, 2015 | 02:56 AM
test point's Avatar
I did but that is some super strong double backed tape under there. A heat gun and a snap off razor knife with the blade extended eased it up without bending. Take you time.
Old Feb 12, 2015 | 03:02 AM
The Tread Plate?
If so - YES. The insert is glued in place and covers the three fixing screws.
It's very easy to damage the insert. I used a wooden spatula the lift the end on mine and then cut through the glue using a length of nylon fishing line in a sawing motion.
Old Feb 12, 2015 | 10:03 AM
dsnyder586's Avatar
I gently lifted the kick plate from the seat side and put a 5-in1 (painting tool) to keep it up while I slid the carpet out and removed the side panel from underneath.
It can be done carefully- the correct way would be to replace the stick that covers the bolts, but the workaround is ok if you are careful- I have done it twice on the same car FYI.
Old Feb 12, 2015 | 10:20 AM
WhiteXKR's Avatar
Once removed keep the adhesive side of the trim clean and it can be reused when activated with some heat without additional adhesive.
Old May 22, 2019 | 08:42 AM
laguillotine's Avatar
Hi,
Can anyone recommend an adhesive for refixing the plates? Obviously something that will allow the plate to be removed again in the future, as refitting one of mine keeps coming back off
Thanks,
FrickenJag
Jun 16, 2025 02:15 PM
dsnyder586
Dec 29, 2024 07:39 PM
user 652867429824
Oct 28, 2015 10:18 AM
sogood
Sep 15, 2015 07:35 AM
