Leaking engine mount
Old Oct 25, 2014 | 07:04 AM
herman4arth's Avatar
Question Leaking engine mount
I have a 1999 XK8 and it appears the driver side engine mount leaks a reddish fluid. Do the engine mounts hold hydraulic fluid and if they leak do they need to be replaced? What if they leak out all fluid and I don't replace them - what bad things can happen?
Old Oct 25, 2014 | 08:19 AM
cjd777's Avatar
Herman, you have a early car but the mount has been superseded to the new one.
MNC7500AB according to SNG, one of our sponsors and mention you are a member and get 10% off.
Oh, yes they are full of fluid and you will get some banging once the fluid runs out, then you could break the bracket, engine falls, can't steer the car, hoses split, you get the picture, REPLACE IT!
Wayne
Old Oct 25, 2014 | 10:06 AM
Gus's Avatar
Gus
I recently replaced my engine mount on the drivers side the link below will show you how.
Link Engine Mount Drivers Side JagRepair.com - Jaguar Repair Information Resource
Old Mar 5, 2019 | 07:14 AM
RaceDiagnostics's Avatar
Thanks for the how to Gus,
I dropped my subframe today and one of the mounts fell out with it.
Looks tricky to get on the top bolt and I bet its going to be very tight, hope it doesn't spin too.
Old Mar 5, 2019 | 11:16 AM
Well that did not go smoothly.
When I levered my home made spanner, the nut and remains of the mount just spun.
So I had to grind it out, so three hours later.
Old Mar 5, 2019 | 04:46 PM
Gus's Avatar
Gus
It is never without opportunities!
Gus
www.jagrepair.com
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
sogood
Sep 15, 2015 07:35 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
OkieTim
Sep 2, 2015 12:48 PM
