Leaking Refrigerant
Old Jun 2, 2013 | 06:28 AM
jafari's Avatar
Question Leaking Refrigerant
Hello Everybody;
(the opposite of )
Summer is well and truly in full swing here in Amman, Jordan and it feels like 37 C (100 F). This is probably why fate has dealt me a leak in my refrigerant, just because...
2-3 days after stocking up on refrigerant the AC stops working again (no error message, but no cool air either).
The guys in the shop said that they could not detect any leaks around the compressor or the engine bay (UV method), and that the leak would probably be in the components behind the dashboard. I guess that would mean a leak in the "Air Conditioning Control Module" or A/CCM? Should I try to pull it out and detect leaking dye via UV light? Does this make sense to you guys?
Old May 21, 2014 | 08:35 AM
jafari's Avatar
Old May 21, 2014 | 08:58 AM
motorcarman's Avatar
The 'EVAPORATOR CORE' is the part that really can't be looked at for leaks because it is inside a 'box' in the dash.
If you are reasonably sure that there are no leaks elsewhere, then it might be the evap core.
bob gauff
Old May 21, 2014 | 09:02 AM
WhiteXKR's Avatar
The ACCM is purely electronic...there will be no leaks there.
Old May 21, 2014 | 10:03 AM
test point's Avatar
A couple different AC shops searched my first car for leaks without any solution. Finally, I bought a freon sniffer to do it myself. The pros had pointed me to the evaporator since after dyes and UV search nothing showed up that could be seen. Nothing showed up on the evaporator either until I turned the fan to the lowest position and then it started to sing. Unfortunately the cost of replacing the evaporator core is probably more than the value of the car.
The problem was solved when another driver ran a traffic signal and totaled the car.
Old May 21, 2014 | 11:49 PM
Jdub's Avatar
ud
Sounds to me like your ac got overcharged. If the problem didn't occur until your ac was recharged I would suspect the either put in too much oil or refrigerant.
Old May 22, 2014 | 08:48 AM
batroute's Avatar
+1 on that - are you sure the car was short of refrigerant initially?
Did they put a set of gauges on the system or just put gas in?
Too much refrigerant plus high ambient will make the system cut out on the high pressure switch.
Poet
Oct 2, 2015 09:00 AM
ahunt4
Sep 25, 2015 03:43 AM
arskemp
Sep 21, 2015 02:19 PM
Tim Goz
Sep 17, 2015 09:11 AM
Vee
Sep 13, 2015 12:19 PM
