For long downhill runs - throw it into "manual"?
Old Feb 6, 2016 | 02:46 PM
cyber3d's Avatar
Default For long downhill runs - throw it into "manual"?
So, here in Southern California we have a long, steep hill (the 101Fwy into Camarillo, CA). Would putting it into 3 or 2 damage the transmission when going down a really long and steep hill?
Old Feb 6, 2016 | 03:11 PM
White Bear's Avatar
Putting the transmission in manual mode to hold your speed on a long downhill run will not hurt it at all, though I doubt you'll need to use 3rd or 2nd gears. In fact it's a good idea, it saves your brakes for when you really need them, and reduces brake wear.
Regards,
Old Feb 7, 2016 | 10:29 AM
Jandreu's Avatar
+1, I use the manual gate all the time going from my house down Haleakala Hwy on Maui. 8 miles long and 2000' to sea level. Often use the manual gate to slow down for traffic lights, as noted this really saves the brakes!
Old Feb 7, 2016 | 12:31 PM
SeismicGuy's Avatar
I know that hill well!! Whenever going down the hill in any car I have owned I always downshifted my automatic trans cars into a lower gear--doesn't hurt and saves the brakes.
The most harrowing experience I had with this hill was many years ago going up the hill in a rented Ford Pinto that had a failing fuel pump. It was like a bad (dangerous) comedy trying to coax the car to the crest.
Doug
Old Feb 8, 2016 | 07:30 AM
kreyszig's Avatar
+1: saves brakes and *fuel*
Old Feb 8, 2016 | 09:41 AM
fmertz's Avatar
The flip side of the argument is that, when in doubt, it is better to put wear on a $50 set of brake pads than putting heat and wear into a $5,000 transmission. Obviously, this argument holds only up to the point where the brake fluid boils or the pads glaze from heat...
Old Feb 9, 2016 | 09:43 AM
toaster's Avatar
Nothing more to say.
Old Feb 12, 2016 | 01:02 AM
cyber3d's Avatar
Doug
Imagine trying to go up that hill in a 1974 Triumph Spitfire! Did that for over a year.
Old Feb 12, 2016 | 02:57 AM
......... Would putting it into 3 or 2 damage the transmission when going down a really long and steep hill?
Not only will it not do any damage, it is even recommended in the Driver's Handbook:
HectorM52
Jun 13, 2016 07:30 PM
Qgregg
Feb 7, 2016 05:32 AM
spedos
Feb 4, 2016 09:37 PM
Sabrina
Feb 4, 2016 07:16 PM
Sparkinlarkin
E type ( XK-E )
Feb 3, 2016 11:47 AM
