Michelin Pilot tire wear
Old Jan 25, 2023 | 08:24 AM
66RBS's Avatar
Default Michelin Pilot tire wear
re 2003 XK8 conv
Previous owner purchased Michelin Pilot A/S 3 tires in 2018 and had alignment.
At Costco today and they said they are worn out down to 2/32 on front and wouldn’t balance them. I have maintained proper tire pressure (32/34) during my ownership.
11000 miles. I expect some reduction in mileage because I can’t rotate.
is this normal?
anyone getting better mileage with different brand
Old Jan 25, 2023 | 10:18 AM
Jon89's Avatar
On my wife's 2006 XK8, the two sets of front Yokohama YK580 tires I ran on that car (245/40/19 at 32 psi) lasted 45,000 to 48,000 miles for each set. The three sets of rear Yokohama YK580 tires I ran on that car (255/40/19 at 29 psi) lasted 32,000 to 34,000 miles on each set. She did a lot of highway driving back and forth from North Carolina to Florida to visit her now-deceased parents. Those tires were manufactured only for Discount Tire and are no longer available....
I rotated the tires from side to side on the same axle every 6,000 miles....
You may want to research whatever Yokohama tire replaced the YK580 as well as the Continental ExtremeContact DWS 06 tire....
Old Jan 25, 2023 | 10:21 AM
Pistnbroke's Avatar
I checked these tyres out here in the uk and they cost around 350 pounds each. I usually pay about 110 pounds for two tyres and about 10 pounds each for fitting.
Sounds like a rip off to me ....I expect a tyre to last 30,000 miles
Old Jan 25, 2023 | 12:55 PM
Rex's Avatar
Rex
Had Michelins on daily driver Honda with 100k km warranty, they wore out in 40k km, Michelin covered 60% of replacement cost.
Old Jan 25, 2023 | 02:45 PM
zray's Avatar
Every tire brand I’ve tried has prematurely worn in the center of the tread when I’ve had the tires inflated to the normal specification listed in the owners manual. That includes Michelin, Pirelli’s, & Goodyear’s.
Center tread wear is a classic sign of overinflation.
The owners manual also lists an alternative tire pressure setting called “Comfort - speeds under 100 mph”.
I ended getting the best tire wear by setting the pressure at a mid-point between the normal setting and the comfort setting.
That way I don’t feel endangered on those occasions when I can hit the throttle wide open for a few brief seconds, and inadvertently exceed 100 mph ….
Old Jan 29, 2023 | 07:48 AM
ccfulton's Avatar
Inadvertently you say?
Old Jan 29, 2023 | 08:17 AM
zray's Avatar
watching the road, pressing the accelerator, and watching the speedometer ?
Can only manage two out of three.
Z
Old Jan 29, 2023 | 08:57 AM
wymjym's Avatar
Z
Hoping for the first two!
My driving position always blocks any view of the speedometer...I just enjoy the drive.
wj
Old Jan 29, 2023 | 09:31 AM
rothwell's Avatar
Originally Posted by 66RBS
re 2003 XK8 conv
is this normal?
Doubtful this is a tire quality problem. If the car is properly set up those tires will last a good long time.
I went thru one set of those on my 2004 XK8 and they never had wear issues. Put a 2nd set on that car because the first set was so impressive. When I sold that car the 2nd set still looked perfect with zero uneven wear.
Pretty sure you have a car/setup problem, not a tire problem. I would not mount another set till I got the setup sorted.
Old Jan 29, 2023 | 12:26 PM
zray's Avatar
”…..I have maintained proper tire pressure (32/34) during my ownership….”
Is the wear even all the way across ?
Knowing that can facilitate the troubleshooting.
With that pressure, I had wear in the center of the tread.
As mentioned above, when I reduced the pressure, the wear was even .
Z
jagophile
Jan 12, 2023 09:47 AM
Vauxi
Jun 28, 2021 11:30 AM
cpq100
May 16, 2021 09:51 PM
cliff328
Dec 22, 2010 09:17 AM
brgjag
Nov 9, 2009 10:21 AM
