MOT fail on fog lamp tell tale light
Old Sep 4, 2021 | 02:42 AM
dibbit's Avatar
Originally Posted by drmike
This is what I was looking at, not my PCB but identical. What's the blue thing?
I can't see any issues with the board. I do have a friend who can test these things but he probably will take some persuading. I have a system that should now pass the test.
The blue thing top right is a capacitor. The blue bulbs along the bottom are filament bulbs with a sleeve. There are quite a few components on that board that can easily be tested by someone who knows how to do it - it could be as simple as a failed component. If you don't care about any of the other tell tales, you could just place a small bulb/LED wired to your fog light, next to/in place of the non working fog light LED.
Just a thought - have you checked the fuse? Drivers side fusebox #6 5A
BTW if you do pull that board out again, take some hires pictures of both sides and post them on here - it might be possible to spot something you missed.
Old Sep 4, 2021 | 03:29 AM
drmike's Avatar
Thanks. I checked the fuse - which I think is shared anyway.
If I take it out again I expect and hope it will be to fit a replacement switch set
Old Sep 4, 2021 | 07:20 AM
dibbit's Avatar
It's obviously a lot easier just to replace it with a working unit, but the fault is going to be so simple I'm sure it would be easy to fix. There doesn't appear to be anything complex on that board, but given the effort in getting the board in and out of the dashboard a swap is the easiest repair.
Old Sep 9, 2021 | 10:18 AM
drmike's Avatar
Just to close the thread. The MOT tester accepted my bodged LED and an Italian tune up seemed to clear the cobwebs and the emissions was a good pass.
I realised that in the previous 12 and possibly 18 months it had done under 100 miles and I'd been driving like a nervous vicar holding a cup of tea as I haven't checked the cam chain tensioners yet. So, a 40 mile round trip to SNG Barratt with some higher revs and then a good blast before the test seems to have done the trick.
Old Sep 22, 2021 | 06:07 AM
drmike's Avatar
Just to reopen the thread.
I bought a used but known good switch set and the same problem persists.
So, it must be wiring away from the switch that's at fault. Probably an earth, I think you can get the pinout for the connector somewhere so I will have to look at that and bodge an earth for the LEds.
Old Sep 22, 2021 | 09:58 AM
Here's the Electrical Guide extract for exterior lighting.
File Type: pdf
Old Sep 22, 2021 | 11:34 AM
drmike's Avatar
Thaks for that and I found this thread amongst others that push me towards Fuse 3!
Old Sep 27, 2021 | 11:42 AM
  #28
drmike's Avatar
And fuse 3 was bust. Now I not only have tell tale lights in the cab I have some heat as well! Fuse 3 does the heater pump as well.
Now to throw the dice on the air con with a fifty quid recharge.
frank barone
Oct 16, 2019 11:37 AM
pragmatic
Jun 19, 2018 06:44 PM
sidecar
Mar 24, 2016 02:01 PM
Rey
Feb 1, 2013 07:02 PM
tommyd
May 15, 2012 06:57 PM
