My ABS is back!
Old Sep 29, 2022 | 07:07 PM
Stamford's Avatar
Default My ABS is back!
For about a year my ABS light's been on. Being a pessimist, I figured it was likely a solder failure in the brake module. But while I had my wheels off to do the brakes, I decided to clean off the ABS sensors. Took them out and they looked pretty clean; no great lumps of filthy grease and road dirt on them. Washed them off in the sink, reinstalled them, et viola, no more ABS light and the system does work as I found when I spun the wheels on loose gravel. Perhaps the easiest, cheapest Jag repair ever!
Old Sep 30, 2022 | 06:02 AM
Jon89's Avatar
It indeed is worth it to take the time to scrub the wheel speed sensors with a toothbrush and dish soap at least every year or so. Been doing it at each tire rotation since I learned the trick in early 2013 and have not seen an ABS warning light since....
Old Oct 1, 2022 | 06:52 AM
dibbit's Avatar
I do like the idea that a slightly large violin played a part in all this. Just think what you could fix with a cello.
Old Oct 1, 2022 | 06:57 AM
Jon89's Avatar
Or an upright bass....
Old Oct 1, 2022 | 08:09 AM
Stamford's Avatar
Would a cello resolve my crappy A-arm bushings?
Old Oct 1, 2022 | 10:41 AM
Jon89's Avatar
That issue would probably need a tuba....
Old Oct 1, 2022 | 11:54 AM
NorXKR's Avatar
WHAT????
A Jag repair without purchasing a new battery???
Well you did not ask for advice, or else you would have a new battery by now
Old Oct 2, 2022 | 02:42 AM
dibbit's Avatar
No, but for electrical faults the wiring diagram is full of cymbals.
I'll get my coat.
Old Oct 2, 2022 | 02:42 PM
Stamford's Avatar
Originally Posted by NorXKR
WHAT????
Did that last year only to find it wasn't the problem. (Although it was the original 16-year-old one with about 115,000 miles on it.)
Old Oct 3, 2022 | 09:27 PM
Stamford's Avatar
I was tempted to edit my typo, but it was too funny.
Dukejag
Nov 9, 2021 12:36 AM
Saspc
May 26, 2016 05:58 PM
speedyxjs
Nov 6, 2015 10:19 PM
daboss085
Apr 7, 2012 03:24 PM
