Need Pinout for 2001 base radio connector
Old 12-31-2012, 01:08 PM
randyb's Avatar
Default Need Pinout for 2001 base radio connector
Specifically I need to know what pinouts are used for the front speakers?
Old 12-31-2012, 04:47 PM
plums's Avatar
Received 2,167 Likes on 1,611 Posts
Try the elecrical diagrams. There should be a link in the stickies.
Old 01-02-2013, 10:35 AM
randyb's Avatar
I did, there is a 2002 diagram, but it does not match my car.
Old 01-02-2013, 02:40 PM
stevepaa's Avatar
I have that diagram, I'll try to look tonight.
Old 01-03-2013, 01:35 PM
stevepaa's Avatar
left front speakers are IC19-3,-8
right side are IC 19-10, -9
IC19 is a 12 pin multilock white connector
randyb (01-04-2013)
Old 01-04-2013, 12:31 PM
randyb's Avatar
Thank you!!
And can you tell me where pin 1 is?
left upper, left lower, etc...
Old 01-07-2013, 11:37 AM
stevepaa's Avatar
IC19-3 is yellow
IC19-8 is yellow/red stripe
IC19-10 is blue/yellow stripe
IC19-9 is blue
pins are numbered on the connector, you may need a magnifying glass
does it look like this
174481-1 Product Details - TE
or this
174933-1 Product Details - TE
Old 01-14-2013, 11:00 AM
randyb's Avatar
I do not have either of these connectors, mine is a 26 pin yellow connector that says FORD on it.
BTW: Yellow and yellow/Red did not bring on the left front speakers for me.
Anybody got a wiring diagram for a 2001?
Old 01-14-2013, 01:20 PM
Paul Pavlik's Avatar
U.S. 2001 XKs were delivered with Premium Audio as Standard.
These are Standard and Premium Audio Diagrams:
Note: You can use the Zoom capability of your .pdf Reader for a clear View.
File Type: pdf
File Type: pdf
Old 01-14-2013, 02:33 PM
randyb's Avatar
Thanks, I have the amp, but the diagram shows the speaker wiring into the amp, but not the head unit.
Do you happen to have that wiring diagram?
Old 01-15-2013, 09:31 AM
stevepaa's Avatar
That yellow 26 pin connector is IC20..and there are no pins on that connector that go to speakers AFAIK.
You will have to tap into IC 15 an 18 pin white multilock 070 at the amplifier in the right side trunk.
There is a harness from radio to amp but I don't know pinouts or audio level outputs on those in -115 pdf above.
randyb (01-15-2013)
Sprayall
05-30-2021 08:13 AM
cissdm
05-03-2016 06:02 AM
picard
10-12-2015 11:56 AM
TexasCat
09-08-2015 04:36 AM
Sprayall
09-03-2015 07:49 PM
Quick Reply: Need Pinout for 2001 base radio connector
