New Guy Here - Please advise..
Old Feb 20, 2008 | 08:24 PM
H20boy's Avatar
Default RE: New Guy Here - Please advise..
i'd check to make sure the tire pressures are correct, every time I take mine into the oil change place, they always set it to 32psi all around...idiots. Staggered wheels are 32 front / 34 rear. on a 1300 mile trip, id hate to have it wrong and get some quick, uneven tire wear.
Wooden knob is MUCH cooler than the leather ones. Trust me, you'll like handling it while driving. lol. sounded bad...
Old Feb 20, 2008 | 11:56 PM
H20boy's Avatar
ORIGINAL: costpenn
3) Any other things I should be watching out for in taking this bad boy on a 1300 mile drive?
Yes,
Old Feb 21, 2008 | 04:35 PM
FactoryJaguarTech's Avatar
H20 Boy....I also, in fact everyone at the dealer sets the tires to 32. Except the new XK because that is 33 rear and 30 front.
Just saying.
Anyway, check the oil levels and coolant levels before you go. Get it to operating temperature before you hand over the cash. Just let it idle and peridocially give it some gas so it warms up. Make sure heater comes on. Temp gauge should be bang in the middle.
Wood shift knob was correct for 2002.
Old Feb 21, 2008 | 07:58 PM
GordoCatCar's Avatar
Dont forget to pack a tool kit w/ screwdrivers, wrenches, sockets, duct tape, flashlight... you get the picture. It also wouldnt hurt to have some fuses. It would be nice to also have spare radiator hoses, belts, and head/tailight bulbs; but thoses are items you will probably pickup later as you work on regular maintenance. gordo
Old Feb 21, 2008 | 08:37 PM
jag_genius's Avatar
i wud check your tires.. i got 4 or 5 guys buying cars from ebay in the states.. then drove to canada with the front tires showing metal.. not really safe..
Old Feb 21, 2008 | 10:21 PM
I would definitly take a thermostat and an 8mm socket and ratchet and some coolant. Just in case. But do what I said with checking levels and getting car to operating temp before you go. You will be ok.
Old Feb 22, 2008 | 01:15 PM
Jack Rabbit's Avatar
" 3) Any other things I should be watching out for in taking this bad boy on a 1300 mile drive?"
Yeah, SNOW! They aren't so good in it!
Old Feb 23, 2008 | 02:34 PM
H20boy's Avatar
Well, the first couple times I used the lights...my lights condensed as well, I think it is from the dealer prep/detailing using high pressure water/soap...gets into the headlights. Best way to get rid of it for good is to remove that clear plastic cover on the headlight (easy to see under the hood) and turn the turn signal bulb (and partially remove it from housing) to get some circulation going. It should clear up in an hour or so. Since then, I haven't had any condensation.
Can't wait to see the pics...nice choice on the cashmere interior, I think it stays nicer looking longer (and cooler) than the black does.
Old Feb 23, 2008 | 11:26 PM
If the car is under warranty, the dealer will replace the headlamp assemblies for the condensation.
kossevv
Feb 21, 2021 12:49 PM
skyryder
Mar 25, 2016 08:18 PM
S00tlyfe
Sep 15, 2015 08:07 PM
diablomkii
Sep 10, 2015 12:14 AM
